very high temp exhaust paint, where to get it |
joeav8tor |
May 13 2005, 09:47 AM
Member Group: Members Posts: 408 Joined: 23-January 05 From: mattituck, Long Island NY Member No.: 3,493 |
hello to all,
I ordered very high temp paint (Grey) from stoddards....it has been out of stock and back ordered from the manufacturer for over 6 weeks...(the story is a long one) I ordered it from stoddards because I wanted it to be as close to the original color as possible...does anybody know of another place that I can get the VHT paint....I am trying to get my motor back into the car, and I already sandblasted the exhaust parts...thanks in advance...I am posting a picture of my 73 914 with 13,900 miles on jackstands...thanks in advance! (IMG:http://www.914world.com/bbs2/html/emoticons/flag.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/flag.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/flag.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/flag.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/flag.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/flag.gif) Joe Attached image(s) |
TravisNeff |
May 13 2005, 09:54 AM
check your local Flaps. I used a high temp silver on mine and had been a few thousand miles and no discoloration (yet).
A sure fire substitute is cold gavlanizing compound, check the classifieds for a 500 mile OE banana muffler for the color it will look. |
StratPlayer |
StratPlayer Group: Members Posts: 3,278 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
Try Bill Hirsch paints, very good product
http://www.hirschauto.com/acb/showprod.cfm...bjectGroup_ID=8 |
Joe Bob |
May 13 2005, 10:00 AM
Barbeque paint.....any local hardware store....ain't nutin' special.
9146R |
May 13 2005, 10:01 AM
Member Group: Members Posts: 223 Joined: 28-September 04 From: alamo ca Member No.: 2,849 |
I powder coated mine (silver)...works very well @ high temp...has lasted ~ 3 years...but costly vs painting.
Eric_Shea |
May 13 2005, 10:03 AM
ArtechnikA |
May 13 2005, 10:21 AM
Brad at NLA in Reno (Sparks, actually...) sells a very accurate color match, if you're going for that concours-quality finish
DougC |
May 13 2005, 01:23 PM
Senior Member Group: Members Posts: 949 Joined: 6-July 04 From: Dallas, TX Member No.: 2,307 |
Will store bought heat paints work on headers (gets hotter than mufflers)? I assumed you'd need to have them coated by one of the "jet-hot" type coating companies. They are pretty expensive and I'd do it myself if something else would work. The new bursch /6 headers arrived chipped in several places and I want to eliminate early rusting if possible.
Doug C |
jgiroux67 |
May 13 2005, 02:27 PM
Guitar Shredder Group: Members Posts: 593 Joined: 4-June 04 From: Turlock, CA Member No.: 2,157 |
You could just use the high heat paint thats at any auto store. It's like $4 a can, a couple coats should do the job.
Eric_Shea |
May 13 2005, 04:53 PM
I wouldn't use rattle can stuff for these pieces. But... it' up to you. It usually lasts about a week before it looks like it does in your first picture. The POR15 stuff is good for 1400deg. I believe Jim has some on his and it still looks great. Strat?
Regarding the headers... I stripped them straight away. That paint they come with blows. I did the POR15 FM Gray on those as well. |
StratPlayer |
May 13 2005, 06:31 PM
Yes I did my muffler in POR20 Black Velvet and it still looks as good as the day I painted in on, that was almost 2 years ago. Great stuff, I refinished a set of stock 75-76 exchangers and painted them with the Bill Hirsch paint, hirsch paint good for 2k degrees.
joeav8tor |
May 14 2005, 04:35 AM
thanks for the info!
(IMG:http://www.914world.com/bbs2/html/emoticons/flag.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/flag.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/flag.gif) Joe Sedotto |
J P Stein |
May 14 2005, 08:04 AM
Get that Bursch paint off of there....if you don't, the heat will....that is to say, it is NOT high temp, it's just black (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) You have to remove it to put on any kind of hi-temp coating. I use rattle can Stove paint...cheep, easy to find. I recoat every couple of years.....gone 6-7 years with no rust. If you can get 10 years out of a set of headers, you're doin' gud. They will die from the inside so's there's no sense spending a bunch of money on trick coatings....me thinks (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) Better to blow it on some CF wheels....... |
Type 4 |
May 14 2005, 11:39 AM
Member Group: Members Posts: 412 Joined: 30-September 04 From: Costa Mesa Calif. Member No.: 2,866 |
If you are looking for a good quality product use Black Satin you can apply it at home there is no need to bake it.
I have used it both baked and not bake It works wells either way. http://www.techlinecoatings.com/Exhaust.htm |
Lo-Fi Version | Time is now: 16th May 2024 - 05:26 PM |
