Engine Lid Pops Open, ....any bump |
7TPorsh |
Jun 19 2017, 10:21 AM
7T Porsh Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California |
I took my engine lid off to work on the car and bend the mounting tabs slightly to align the lid. Now reinstalled....the metal rod that latches on the lock/latch is barely long enough to engage.
Lid closes and locks but any little thing pops it open with the latch still closed. The engaging L shaped rod is not long enough. Has anyone else had this problem? Is the solution putting washers under the lock to bring it away from the wall? |
GregAmy |
Jun 19 2017, 11:31 AM
Advanced Member Group: Members Posts: 2,284 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
I had the same problem; mine was that the part that goes into the latch wans't long enough.
I fixed it with a simple solution: take a longer correct-sized bolt (6mm threads I think?) with an unthreaded shank, cut off the hex head, use some light heat and bend in a vice to a 90-degree angle, and then trim and grind the ends off to desired length. Unthreaded part fits into the latch, of course. No more popping out on hard bumps. Wife is no longer entertained. |
Lo-Fi Version | Time is now: 3rd May 2024 - 06:51 PM |
