Transmisson, 1st Gear Question |
xperu |
Jun 24 2017, 03:38 PM
TEXAS Group: Members Posts: 597 Joined: 13-June 06 From: League City Texas Member No.: 6,213 Region Association: None |
I drive a 74 4 cylinder. W pulling my shift into 1st, say at a complete stop I have a very difficult time pulling the shift into 1st and sometimes I have to put in 2nd to go. Most of the time I will put it in 1st while coasting to a stop. When going through the rest of the gears the trans shifts very smooth. Any help would be appreciated. Mike
mlindner |
Jun 25 2017, 05:16 AM
Senior Member Group: Members Posts: 1,521 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
Mike, the first gear slider and synchro can be changed without a transmission tear down.....Only need to take off rear cone where first and reverse reside. Best, Mark
stownsen914 |
Jun 25 2017, 06:02 AM
Senior Member Group: Members Posts: 913 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
Other common causes of shifting issues that may be looking into if the above suggestions don't work:
Loose set screw in the knuckle on the shift rod just behind the engine firewall. Shift linkages bushings worn. One in firewall, another back where linkage attaches to the trans. Less likely, but misaligned shift linkage (just below shifter, where it attaches to shift rod). |
Lo-Fi Version | Time is now: 17th May 2024 - 09:41 PM |
