Transmisson, 1st Gear Question |
xperu |
Jun 24 2017, 03:38 PM
TEXAS Group: Members Posts: 597 Joined: 13-June 06 From: League City Texas Member No.: 6,213 Region Association: None |
I drive a 74 4 cylinder. W pulling my shift into 1st, say at a complete stop I have a very difficult time pulling the shift into 1st and sometimes I have to put in 2nd to go. Most of the time I will put it in 1st while coasting to a stop. When going through the rest of the gears the trans shifts very smooth. Any help would be appreciated. Mike
Elliot Cannon |
Jun 24 2017, 03:44 PM
Make sure the clutch is properly adjusted.
xperu |
Jul 6 2017, 02:41 PM
Make sure the clutch is properly adjusted. I made the clutch adjustment................ first time I've done this, but it works much better. 1st gear slides right in. I replaced the motor mounts and all bushing a couple of years ago. Thanks everyone. Always a good education here! Thanks Mike |
Elliot Cannon |
Jul 7 2017, 12:45 PM
Make sure the clutch is properly adjusted. I made the clutch adjustment................ first time I've done this, but it works much better. 1st gear slides right in. I replaced the motor mounts and all bushing a couple of years ago. Thanks everyone. Always a good education here! Thanks Mike When trouble shooting a problem, you should always do the easiest thing first. In other words, it's a lot easier to first make sure the clutch is adjusted properly than it is to pull the engine and trans. to check the clutch fork. IMHO |
Lo-Fi Version | Time is now: 17th May 2024 - 09:41 PM |
