Transmisson, 1st Gear Question |
xperu |
Jun 24 2017, 03:38 PM
TEXAS Group: Members Posts: 597 Joined: 13-June 06 From: League City Texas Member No.: 6,213 Region Association: None |
I drive a 74 4 cylinder. W pulling my shift into 1st, say at a complete stop I have a very difficult time pulling the shift into 1st and sometimes I have to put in 2nd to go. Most of the time I will put it in 1st while coasting to a stop. When going through the rest of the gears the trans shifts very smooth. Any help would be appreciated. Mike
Elliot Cannon |
Jun 24 2017, 03:44 PM
Make sure the clutch is properly adjusted.
xperu |
Jul 6 2017, 02:41 PM
Make sure the clutch is properly adjusted. I made the clutch adjustment................ first time I've done this, but it works much better. 1st gear slides right in. I replaced the motor mounts and all bushing a couple of years ago. Thanks everyone. Always a good education here! Thanks Mike |
Elliot Cannon |
Jul 7 2017, 12:45 PM
Make sure the clutch is properly adjusted. I made the clutch adjustment................ first time I've done this, but it works much better. 1st gear slides right in. I replaced the motor mounts and all bushing a couple of years ago. Thanks everyone. Always a good education here! Thanks Mike When trouble shooting a problem, you should always do the easiest thing first. In other words, it's a lot easier to first make sure the clutch is adjusted properly than it is to pull the engine and trans. to check the clutch fork. IMHO |
xperu |
Jul 11 2017, 08:22 AM
Make sure the clutch is properly adjusted. I made the clutch adjustment................ first time I've done this, but it works much better. 1st gear slides right in. I replaced the motor mounts and all bushing a couple of years ago. Thanks everyone. Always a good education here! Thanks Mike When trouble shooting a problem, you should always do the easiest thing first. In other words, it's a lot easier to first make sure the clutch is adjusted properly than it is to pull the engine and trans. to check the clutch fork. IMHO Funny, but very true. Mike Kelly |
Lo-Fi Version | Time is now: 17th May 2024 - 09:24 PM |
