Shifter help, Read the search post. |
80cap |
Jun 26 2017, 03:51 PM
Member Group: Members Posts: 317 Joined: 6-February 15 From: ohio Member No.: 18,405 Region Association: None |
Ok
I searched the web and the Pelican tip said to place the trans in reverse then slide the coupler on the rod by going from first to reverse. Ok how do you tighten the pinch bolt? (IMG:style_emoticons/default/headbang.gif) Brian |
theer |
Jun 26 2017, 04:10 PM
Senior Member Group: Members Posts: 676 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States |
There is a set screw (hex drive - should be replaced, not re-used), no pinch bolt. Unless I am misunderstanding the question.
ljubodraz |
Jun 26 2017, 04:22 PM
Member Group: Members Posts: 64 Joined: 4-May 14 From: Chicagoland Member No.: 17,312 Region Association: Upper MidWest |
Rotate the shifter base, once unbolted, and rotate 90 degrees horizontally to expose where the rod enters the shifter as well as the pinch bolt. Apologies if I misunderstood the question as you must have done this already if you disconnected it.
80cap |
Jun 26 2017, 04:24 PM
It is not the cone screws it is the pinch bolt on the coupling on the shifter. Once I slide the coupler to the reverse position the pinch bolt is not accessible . I found a post by Dr Evil who says to use third gear instead of reverse but the bolt is still not accessible.
Brian (IMG:style_emoticons/default/beer3.gif) |
80cap |
Jun 26 2017, 04:28 PM
80cap |
Jun 26 2017, 04:40 PM
Ok it still is not accessible by rotating the base. If I try to use Dr. Evil way to use 3rd gear it should work. I'm starting over tomorrow.
Brian |
ljubodraz |
Jun 26 2017, 08:20 PM
You're not making sense Brian. It's hard to help without a better explanation of what you've done so far and what you're trying to do overall. (IMG:style_emoticons/default/confused24.gif)
malcolm2 |
Jun 26 2017, 08:35 PM
snap some pictures....
you talking about here? |
bdstone914 |
Jun 26 2017, 09:14 PM
bdstone914 Group: Members Posts: 4,516 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
80cap |
Jun 27 2017, 04:49 AM
It is a side shift.
Brian |
dcecc1968 |
Jun 27 2017, 06:19 AM
Member Group: Members Posts: 251 Joined: 31-December 12 From: Concord, NC Member No.: 15,313 Region Association: South East States |
Brian,
I'm dealing with the same issue you are. See my post entitled "Shift Bar Linkage Adjustment tips" for some good advice provided by others. However, mine is a side shift with the pinch bolt accessible from the top. -Don |
GregAmy |
Jun 27 2017, 06:27 AM
Advanced Member Group: Members Posts: 2,290 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
http://www.tangerineracing.com/transmission.htm
Precision Shifter Adjuster at the bottom. Also includes a little bit of short shifter action. Installed this in the race car a couple weekends ago (at the track, even) and I'm a convert. |
80cap |
Jun 27 2017, 07:23 AM
I just talked to McMark. On a sides shift it can only be done in neutral. Trial and error method. When my bank account recovers from all the 914 trauma I will probably spring for the adjustable coupling.
Brian |
arne |
Jun 27 2017, 08:48 AM
Serial Rescuer of old vehicles... Group: Members Posts: 737 Joined: 31-January 17 From: Eugene, Oregon Member No.: 20,799 Region Association: None |
I just saw this thread, and agree with McMark. All three of th service manuals I have access to say to do the side shift adjustment in neutral. I just did it after an engine drop and linkage bushing replacement. The process was simple - with the transmission in neutral, adjust fore-aft position by making the lever vertical, then for side-to-side, hold the lever to the 4-5 side while twisting the shift rod in the tunnel access hole clockwise as seen sitting facing forward. The pinch bolt should be easy to tighten at that point.
Lo-Fi Version | Time is now: 8th May 2024 - 07:50 PM |
