80cap
Jun 26 2017, 03:51 PM
Ok
I searched the web and the Pelican tip said to place the trans in reverse then slide the coupler on the rod by going from first to reverse. Ok how do you tighten the pinch bolt?
Brian
theer
Jun 26 2017, 04:10 PM
There is a set screw (hex drive - should be replaced, not re-used), no pinch bolt. Unless I am misunderstanding the question.
ljubodraz
Jun 26 2017, 04:22 PM
Rotate the shifter base, once unbolted, and rotate 90 degrees horizontally to expose where the rod enters the shifter as well as the pinch bolt. Apologies if I misunderstood the question as you must have done this already if you disconnected it.
80cap
Jun 26 2017, 04:24 PM
It is not the cone screws it is the pinch bolt on the coupling on the shifter. Once I slide the coupler to the reverse position the pinch bolt is not accessible . I found a post by Dr Evil who says to use third gear instead of reverse but the bolt is still not accessible.
Brian
80cap
Jun 26 2017, 04:28 PM
Ijubodraz
Why did I not think to do that?
Thanks Brian
80cap
Jun 26 2017, 04:40 PM
Ok it still is not accessible by rotating the base. If I try to use Dr. Evil way to use 3rd gear it should work. I'm starting over tomorrow.
Brian
ljubodraz
Jun 26 2017, 08:20 PM
You're not making sense Brian. It's hard to help without a better explanation of what you've done so far and what you're trying to do overall.
malcolm2
Jun 26 2017, 08:35 PM
snap some pictures....
you talking about here?
bdstone914
Jun 26 2017, 09:14 PM
QUOTE(malcolm2 @ Jun 26 2017, 07:35 PM)
Click to view attachmentFirst clarify if this is a tail shift or side shift. the pinch bolt on the side ahift is below the shifter. tail shift is as pictured at the back of the tunnel
80cap
Jun 27 2017, 04:49 AM
It is a side shift.
Brian
dcecc1968
Jun 27 2017, 06:19 AM
Brian,
I'm dealing with the same issue you are. See my post entitled "Shift Bar Linkage Adjustment tips" for some good advice provided by others. However, mine is a side shift with the pinch bolt accessible from the top.
-Don
GregAmy
Jun 27 2017, 06:27 AM
http://www.tangerineracing.com/transmission.htmPrecision Shifter Adjuster at the bottom. Also includes a little bit of short shifter action. Installed this in the race car a couple weekends ago (at the track, even) and I'm a convert.
80cap
Jun 27 2017, 07:23 AM
I just talked to McMark. On a sides shift it can only be done in neutral. Trial and error method. When my bank account recovers from all the 914 trauma I will probably spring for the adjustable coupling.
Brian
arne
Jun 27 2017, 08:48 AM
I just saw this thread, and agree with McMark. All three of th service manuals I have access to say to do the side shift adjustment in neutral. I just did it after an engine drop and linkage bushing replacement. The process was simple - with the transmission in neutral, adjust fore-aft position by making the lever vertical, then for side-to-side, hold the lever to the 4-5 side while twisting the shift rod in the tunnel access hole clockwise as seen sitting facing forward. The pinch bolt should be easy to tighten at that point.
