Shifter help, Read the search post. |
80cap |
Jun 26 2017, 03:51 PM
Member Group: Members Posts: 317 Joined: 6-February 15 From: ohio Member No.: 18,405 Region Association: None |
Ok
I searched the web and the Pelican tip said to place the trans in reverse then slide the coupler on the rod by going from first to reverse. Ok how do you tighten the pinch bolt? (IMG:style_emoticons/default/headbang.gif) Brian |
theer |
Jun 26 2017, 04:10 PM
Senior Member Group: Members Posts: 677 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States |
There is a set screw (hex drive - should be replaced, not re-used), no pinch bolt. Unless I am misunderstanding the question.
Lo-Fi Version | Time is now: 30th May 2024 - 11:20 AM |
