Shifter help, Read the search post. |
80cap |
Jun 26 2017, 03:51 PM
Member Group: Members Posts: 317 Joined: 6-February 15 From: ohio Member No.: 18,405 Region Association: None |
Ok
I searched the web and the Pelican tip said to place the trans in reverse then slide the coupler on the rod by going from first to reverse. Ok how do you tighten the pinch bolt? (IMG:style_emoticons/default/headbang.gif) Brian |
ljubodraz |
Jun 26 2017, 04:22 PM
Member Group: Members Posts: 64 Joined: 4-May 14 From: Chicagoland Member No.: 17,312 Region Association: Upper MidWest |
Rotate the shifter base, once unbolted, and rotate 90 degrees horizontally to expose where the rod enters the shifter as well as the pinch bolt. Apologies if I misunderstood the question as you must have done this already if you disconnected it.
Lo-Fi Version | Time is now: 19th May 2024 - 04:14 PM |
