Shifter help, Read the search post. |
80cap |
Jun 26 2017, 03:51 PM
Member Group: Members Posts: 317 Joined: 6-February 15 From: ohio Member No.: 18,405 Region Association: None |
Ok
I searched the web and the Pelican tip said to place the trans in reverse then slide the coupler on the rod by going from first to reverse. Ok how do you tighten the pinch bolt? (IMG:style_emoticons/default/headbang.gif) Brian |
80cap |
Jun 26 2017, 04:24 PM
It is not the cone screws it is the pinch bolt on the coupling on the shifter. Once I slide the coupler to the reverse position the pinch bolt is not accessible . I found a post by Dr Evil who says to use third gear instead of reverse but the bolt is still not accessible.
Brian (IMG:style_emoticons/default/beer3.gif) |
Lo-Fi Version | Time is now: 19th May 2024 - 07:56 PM |
