| 7TPorsh |
Jun 28 2017, 10:49 AM
7T Porsh ![]() ![]() ![]() ![]() Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California
I was using lug bolts on my 2.0 Fuchs but now the new set of wheels needs a slightly longer bolt. I would rather swap out the lug bolts for screw in studs.
i believe the size is M14x1.5. I haven't really measured length but I need studs that screw in then have enough length (little more than stock) for the wheel lug nuts. The wheels use ball seat inserts. Anyone have a good set of 16 studs? or recommend a source? thx |
| jmitro |
Jun 28 2017, 11:11 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None
I have a set of brand new studs I was going to use. They are longer than stock (I think either 60 or 80mm long) but I want to go back to stock or at least shorter.
I can get a pic at home |
| stugray |
Jun 28 2017, 11:42 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
| dansvan |
Jun 28 2017, 02:55 PM
Newbie ![]() Group: Members Posts: 34 Joined: 15-June 16 From: Eagle River Alaska Member No.: 20,111 Region Association: None |
I use the above mentioned ones from track-studs as well. Very pleased
| 7TPorsh |
Jun 29 2017, 09:28 AM
Thanks for the lead...these seem to be the current choice for porsche owners...Shopify store so probably run by an enthusiast.... |
| garm |
Sep 11 2019, 04:50 PM
Newbie ![]() Group: Members Posts: 21 Joined: 23-June 18 From: Chatsworth CA Member No.: 22,247 Region Association: Southern California |
Found this thread, and it had exactly what I was looking for. Even the link is still good!
Love 914World |
| Literati914 |
Sep 11 2019, 06:57 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,430 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
I feel safer with the pressed in studs, here are some if you're the same:
https://swayaway.com/product-category/axles...-vw/wheelstuds/ |
Lo-Fi Version | Time is now: 26th November 2026 - 07:48 AM |
