> Car went to half power....are there fuel relays and other little gremlins that blow..., Car runs like rocket...now not so much...must fix...
second wind
post Jul 3 2017, 01:03 PM
Hey guys, my '73 2.0 runs perfect and has d-jet. Just driving up the street notice it sounded weird and wouldn't rev past 4,000 and sounded labored doing so. Still idles but feels like it is on two cylinders or something. Pulled plug wires off each cylinder while running and each cylinder did make a change so all four are firing. I do have a pertronix. I wonder is there a fuel pump relay or other relay that could be messing up? Thank you.
gg
JeffBowlsby
post Jul 3 2017, 01:45 PM
Oiled your dizzy counterweights lately? 1 drop of 30 wt in the center of the dizzy shaft annually is what the manual recommends. When the weights stick, you get slow acceleration.
second wind
post Jul 3 2017, 02:14 PM
QUOTE(Jeff Bowlsby @ Jul 3 2017, 12:45 PM) *
Will give it a go.....funny how time flies....probably has been a year.....thanks,
gg
mgphoto
post Jul 3 2017, 03:19 PM
"If there is a mistake it will find me"
Greg,
Check to see if the dizzy is loose, if not, pull the cap and look at the plate holding the Pertronix, can you move the lug where the vacuum can attaches, with a screwdriver?
Both directions?
Mike
second wind
post Jul 3 2017, 04:35 PM
QUOTE(mgphoto @ Jul 3 2017, 02:19 PM) *
Greg,
Both directions?
Mike
I will give it a try...thanks..
gg
- Lo-Fi Version Time is now: 21st January 2026 - 01:57 PM
