Sail vinyl |
Sail vinyl |
tomh |
Jul 4 2017, 10:36 PM
Member Group: Members Posts: 322 Joined: 28-February 10 From: san jose Member No.: 11,412 Region Association: None |
Over last winter I replaced the sail and roll bar vinyl, I cleaned and sanded all the surfaces and used 3M spray 90. Now it's bubbling and lifting.
Before I tear into it and redo again I need input on what I possibly did wrong in the process. Thanks all |
Kansas 914 |
Jul 5 2017, 09:53 AM
Over last winter I replaced the sail and roll bar vinyl, I cleaned and sanded all the surfaces and used 3M spray 90. Now it's bubbling and lifting. Before I tear into it and redo again I need input on what I possibly did wrong in the process. Thanks all Did you follow this process? http://www.914world.com/bbs2/index.php?showtopic=14625 |
Tom_T |
Jul 5 2017, 01:51 PM
I've had similar results with the 3M adhesive sprays lately - both their 90 & High Temp - & did the type of prep Eric lays out in that link to the sail vinyl techniques, when I redid some of the interior vinyl in our Westy resto in 2013-14.
It just seems to dry, bubble & peel after about 12-24 months - & mine was an interior application - not exposed to direct sunlight. I'm wondering if 3M has changed to formulations to meet CARB & EPA air quality standards, so that it now doesn't work as well as the old stuff? (IMG:style_emoticons/default/confused24.gif) If new adhesives, paints, coatings, cleaners, etc. are changed to be more "environmentally friendly" but then require the use of more material &/or lasts less long & needs to be done more often - again more material used, then couldn't that just offset any saved impacts byt the more volume &/or cumulative product use impacts? Just saying ....! (IMG:style_emoticons/default/dry.gif) (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
tomh |
Jul 5 2017, 03:17 PM
I did study that thread before undergoing the install of the new vinyl. I guess the real question should be what adhesive should we use now. The initial install I did worked and looked very nice then it seems when it got warmer here in the Bay Area it started to get gooey.
Has anyone used any other type adhesive. |
Front yard mechanic |
Jul 5 2017, 04:23 PM
Senior Member Group: Members Posts: 1,163 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
I used the 3m spray on my chevy headliner it too failed in about 18 months so used brush on contact cement made for laminate ! keeping my fingers crossed (IMG:style_emoticons/default/headbang.gif)
Larmo63 |
Jul 5 2017, 06:08 PM
I did my white car and used the brush on stuff out of the can.
It has held up very well. (IMG:style_emoticons/default/first.gif) |
tomh |
Jul 5 2017, 11:42 PM
Sounds like brush on might be the way to go. Might be cleaner also,no real over spray to worry about.
Any particular brand or would any exterior contact cement work? |
Mikey914 |
Jul 6 2017, 05:22 AM
The rubber man Group: Members Posts: 12,669 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
My personal experience has been it needs to completely flash and just be sticky before assembling. If you put it on while there's too much solvent in the glue still, it bubbles.
90quattrocoupe |
Jul 6 2017, 11:53 AM
Member Group: Members Posts: 208 Joined: 4-November 16 From: Long Beach, CA. Member No.: 20,561 Region Association: Southern California |
Anything with VOCs in it or the propellant itself has been changed due to whatever. I have found though that small portions of the original product can sometimes, still be found.
This does hold true for most products from the larger companies like 3m. They sell too much of a product, not to reformulate. I have found that products from VAG, still have the original formulas. You can tell by the smell. They get away with it, because it comes in small quantities, such as less than quart size. I have found this adhesive to be quite good. Greg W. (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-20561-1499363610.1.jpg) |
tomh |
Jul 6 2017, 01:03 PM
Where do you get that, is it a VW product?
90quattrocoupe |
Jul 6 2017, 11:56 PM
porschetub |
Jul 7 2017, 03:38 PM
Advanced Member Group: Members Posts: 4,699 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Over last winter I replaced the sail and roll bar vinyl, I cleaned and sanded all the surfaces and used 3M spray 90. Now it's bubbling and lifting. Before I tear into it and redo again I need input on what I possibly did wrong in the process. Thanks all Never personally had any luck with spray can contact glue,for that reason I don't buy it anymore,used a product called Ados F38,takes high temp,waterproof and sticks really well,brush on and make sure it tacks right off,when all the solvents have vented off it shouldn't bubble. Been using a waterbased glue lately to finish putting down floor planks in my house,now that s#it really sticks,tried it on other applications and it was useless (IMG:style_emoticons/default/confused24.gif) . |
Lo-Fi Version | Time is now: 18th May 2024 - 05:05 AM |
