| North Coast Jim |
Jul 5 2017, 09:35 AM
Member ![]() ![]() Group: Members Posts: 349 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region
Not finding anyone with availability of a used in good shape passenger side SS exhaust I may have to go with the AA offered alternative. Understanding these are produced off the old SSI tooling moved to Taiwan was wondering about Member experience with these items.
I've heard of some issues with the offshore produced Dansk mufflers but not the SS exhausts. Any purchasers out there with input of the quality. Thanks All |
| 914_teener |
Jul 5 2017, 10:15 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,270 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Not sure where mine were manufactured but two of the mounting ears that bolt to the heads cracked. I repaired them by rewelding them and have had no problems since and I would notion from how long I have had them ....8 years or so that they are SSI.
One thing for sure that I know is that if the wrong stainless alloy is used for the tubing and if consideration is not taken on how the forming is done, they will crack. Particulary where the heat cycling and forming stresses are the highest. Other than that I don.t have experience with any manuf in Taiwan. Others may know more history than I. |
| Mikey914 |
Jul 5 2017, 10:56 AM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,785 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
SSI sold the tooling in the last 36 months, I would suspect any issues with cracking and anything else would only be showing up in daily drivers at this point.
| IronHillRestorations |
Jul 5 2017, 11:03 AM
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,958 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None
The biggest issue I have with the reproduction heat exchangers is the sealing surface that bolts to the head.
Stock heat exchangers have a thick sealing surface, but the SSI's flange is only the thickness of the exhaust tubing, which is about 1/3 of the sealing surface. This makes them easily deformed and they are notorious for sealing problems. The other problem that's very typical is the sealing surfaces aren't parallel and most of the time require filing to level. |
| North Coast Jim |
Jul 5 2017, 11:25 AM
| North Coast Jim |
Jul 5 2017, 11:47 AM
| Mark Henry |
Jul 5 2017, 12:10 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
The biggest issue I have with the reproduction heat exchangers is the sealing surface that bolts to the head. Stock heat exchangers have a thick sealing surface, but the SSI's flange is only the thickness of the exhaust tubing, which is about 1/3 of the sealing surface. This makes them easily deformed and they are notorious for sealing problems. The other problem that's very typical is the sealing surfaces aren't parallel and most of the time require filing to level. (IMG:style_emoticons/default/agree.gif) Do not let a gorilla loose tightening them up, M8 = 18ft/lb. If they don't seal up take them off and square up the tubes. Don't just keep cranking. (IMG:style_emoticons/default/rolleyes.gif) |
| Garland |
Jul 5 2017, 03:16 PM
Restoration Fanatic ![]() ![]() ![]() Group: Members Posts: 1,437 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest
Try double gasketing the copper sealing rings, it has work for me in the past.
| reharvey |
Jul 5 2017, 04:38 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 573 Joined: 16-July 08 From: N. E. Ohio Member No.: 9,308 Region Association: North East States |
| reharvey |
Jul 5 2017, 04:39 PM
The biggest issue I have with the reproduction heat exchangers is the sealing surface that bolts to the head. Stock heat exchangers have a thick sealing surface, but the SSI's flange is only the thickness of the exhaust tubing, which is about 1/3 of the sealing surface. This makes them easily deformed and they are notorious for sealing problems. The other problem that's very typical is the sealing surfaces aren't parallel and most of the time require filing to level. (IMG:style_emoticons/default/agree.gif) |
Jul 5 2017, 05:27 PM
Anything in a bind I guess, but I've never used two exhaust gaskets in the port.
| Mark Henry |
Jul 5 2017, 05:40 PM
| jim_hoyland |
Jul 5 2017, 06:53 PM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,148 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
Would stub pipes help ? Thanks i
Lo-Fi Version | Time is now: 21st October 2026 - 01:50 PM |
