WTB: Gas Pedal and Hose |
Ed_Turbo |
Jul 7 2017, 11:51 AM
Member Group: Members Posts: 440 Joined: 5-June 17 From: Hacienda Heights, Ca. Member No.: 21,151 Region Association: Southern California |
TheCabinetmaker |
Jul 7 2017, 11:57 AM
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
braided hose available at any bug shop. Sells by the meter. Bughaus, busdepot, etc. New gas pedal available at 914 rubber, or pelican, or etc. Buy new ones
euro911 |
Jul 7 2017, 12:39 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,848 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
No one is going to pop the linkage off of an accurately reproduced 914 rubber gas pedal to see if it has the factory # on the back - just sayin' |
Ed_Turbo |
Jul 11 2017, 09:31 PM
Bump to the top..
Anyone with an original pedal? PM me |
ndfrigi |
Jul 11 2017, 09:49 PM
Advanced Member Group: Members Posts: 2,928 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
kkid |
Jul 12 2017, 12:36 AM
Member Group: Members Posts: 343 Joined: 18-December 07 From: Oakland, CA Member No.: 8,483 Region Association: Northern California |
While you are here, you will WTB air cooling flaps for your motor.
bdstone914 |
Jul 12 2017, 05:16 AM
bdstone914 Group: Members Posts: 4,515 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
While you are here, you will WTB air cooling flaps for your motor. What he is pointing out is that the air flap rod and flaps is missing. Very important as without them air does not go thru the oil cooler. Add them before you burn up your engine. You are probably missing the thermostat assembly too. |
bdstone914 |
Jul 12 2017, 05:26 AM
Bump to the top.. Anyone with an original pedal? PM me Original gas pedals are about $100 new. What do you figure a used original is worth when you can buy a new afternarket one for under $30? Remember the reason you're replacing the original one is that they fail internally from rust. |
Mikey914 |
Jul 12 2017, 09:04 AM
The rubber man Group: Members Posts: 12,657 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Ahhhhh ............ $20 too much for ya? If you want I can charge $90 if it makes you feel better (IMG:style_emoticons/default/biggrin.gif)
http://shop.914rubber.com/914-Gas-pedal-91...m?categoryId=-1 I'd bet you can't tell the difference Attached thumbnail(s) |
mb911 |
Jul 12 2017, 10:22 AM
914 Guru Group: Members Posts: 6,830 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I actually have an NOS pedal with the stickers still on it. Pm me if interested. I would then buy Mark's .
Lo-Fi Version | Time is now: 7th May 2024 - 04:57 AM |
