> 911 oil filter "drama"
Keith914
post Jul 9 2017, 08:34 AM
I am at final stage of completing my 2.7 911 engine install project. All external oil lines are AN12 stainless steel braided hoses and fittings. I have the scavenger oil feeding directly into an oil filter which is mounted to a bracket with 1/2" fittings for the in and out and for the nipple that the filter screws onto. While starting the engine, as soon as rpm's exceed about 2000 the filter O ring pops out and oil leaks massively. Same result after several attempts. I have a K&N filter that has a large O ring that is not as secure in it's groove as say FRAM filters I am familiar with, and which worked well with this bracket fitting when I had my Type IV in the car. I will be installing a new bracket shortly that has 1/2" in and out hose fittings but a 3/4" nipple for a new typical 911 filter which has a matching 3/4" screw on female fitting. I decided not to install an oil thermostat as I live in a warm climate here in S Cal. Any advice will be welcome.
mb911
post Jul 9 2017, 08:42 AM
I think 1/2" is to small as stock would be 5/8" internally in the tank. This would increase oil pressure to a certain degree. That said something else seems wrong.
Is something stuck on the oil bypass on the engine? Also i would use the oc54 filter myself.
Mark Henry
post Jul 9 2017, 08:44 AM
that's what I do!
Could you explain how you have the oil filter mounted better,
Is it on the tank?
Or are you talking about a remote filter adapter like how you would do full Flow on a T1 or 4?
What brand and # filter are you using?
Fram filters are shit, I used to be a HP-1 lemming till I cut one open.
Mark Henry
post Jul 9 2017, 08:49 AM
that's what I do!
QUOTE(mb911 @ Jul 9 2017, 10:42 AM) *
Keith914
post Jul 9 2017, 09:31 AM
QUOTE(Mark Henry @ Jul 9 2017, 07:44 AM) *
Is it on the tank?
The oil filter bracket is located on the original battery tray - battery is now in front of car.
Steve
post Jul 9 2017, 09:52 AM
I know your trying to save money, but if you bought an aftermarket six tank from mb911 your car would most likely be running now. I would be surprised if it's related to the engine.
Steve
post Jul 9 2017, 09:53 AM
duplicate post
Mark Henry
post Jul 9 2017, 10:52 AM
that's what I do!
(IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif)
Mark Henry
post Jul 9 2017, 10:54 AM
that's what I do!
Not sure what you mean by oil filter bracket.... I'm assuming you mean remote filter adapter.?
Keith914
post Jul 9 2017, 11:06 AM
QUOTE(Mark Henry @ Jul 9 2017, 09:54 AM) *
Yes, like this:
rhodyguy
post Jul 9 2017, 11:16 AM
Should that remote require a Mann filter designed for a 4?
Steve
post Jul 9 2017, 11:20 AM
If your going to go that route, I would check out how Patrick Motorsports does it.
http://www.patrickmotorsports.com/part/rem...ount-set-an-12/
They also list the project cars with pictures on how they use the remote oil filter console.
Stock oil tank would be less work....
Mark Henry
post Jul 9 2017, 11:21 AM
that's what I do!
QUOTE(rhodyguy @ Jul 9 2017, 01:16 PM) *
(IMG:style_emoticons/default/agree.gif) You can use a type 4 fillter, Mann, Bosch, NAPA gold.
You will pop the O-ring on any cheap filter with even a VW type one oil pump.
Way under sized for the large 911 /6 oil pump. You should at least use a remote filter adapter for a tractor/hydraulics.
Keith914
post Jul 9 2017, 11:52 AM
QUOTE(Mark Henry @ Jul 9 2017, 10:21 AM) *
Patrick's console looks like a well made part, but has the same oil in and out AN 12 fittings I will have on my new bracket, and I am guessing that it has a 3/4" nipple for screwing on the filter. I have a new MAHLE filter which has a 3/4" female "nipple". I am going to cautiously try this filter with the new "3/4" bracket/adapter combination before changing to other solutions you have suggested.
Do you have a "adapter for tractor/hydraulics" reference? - I will look on Google.
Mark Henry
post Jul 9 2017, 11:59 AM
that's what I do!
Same thing you have but in 1" NPT, any hydraulic supply house.
Keith914
post Jul 9 2017, 12:09 PM
QUOTE(Mark Henry @ Jul 9 2017, 10:59 AM) *
I should have mentioned my new filter is a MAHLE OC54 from Pelican 911 catalog.
thelogo
post Jul 9 2017, 12:28 PM
Group: Retired Members
Your a brave man sir keith
Putting all this stuff together yourself
By the way the old motor is goin great .
(IMG:style_emoticons/default/pray.gif)
Keith914
post Jul 9 2017, 01:30 PM
QUOTE(thelogo @ Jul 9 2017, 11:28 AM) *
Thanks and I am pleased you are enjoying the 2.36 Ltr.
Mark Henry
post Jul 9 2017, 02:14 PM
that's what I do!
If it's a mahle I'd look elsewhere than the filter, after the filter it's suppose to just dump into the tank, no real restriction.
Just a thought do you have the flow into the filter backwards?
It could be messing with the filter by-pass valve.
Keith914
post Jul 9 2017, 03:15 PM
QUOTE(Mark Henry @ Jul 9 2017, 01:14 PM) *
Mark, Thanks for all your input.
First, flow direction is correct, - this is a remote filter mounting, and is first in line from the scavenger pump - oil flows on to the front cooler, then back to a custom built tank located in the engine compartment - no thermostat - S. Cal!
Next I owe you an apology - the inside non-threaded plumbing in toy old bracket -picture above, is 3/8'" diam, just measured again, and the inlet and outlet ports are 3/8"NPT. My new bracket, just delivered, has 1/2"NPT inlet and outlet ports with corresponding internal plumbing non threaded - much better than smaller old bracket. the filter spin on nipple however is the same 3/4"-16 as the older unit. I need to get AN12 fittings to connect the hoses to these larger 1/2' ports and a good filter to spin on - tomorrow will report back.
- Lo-Fi Version Time is now: 7th December 2025 - 01:11 PM
