> Seatbelt Nut in Long, Anyone know where I can get one?
amfab
post Jul 9 2017, 02:27 PM
I am looking for a seat belt nut/reinforcement thingy in the longitudinal.
I need one, and was wondering if anybody makes this. I am sure I can probably fab something up, but it would be one less thing on my list if someone already makes one.
TIA
-Andrew
Mike Bellis
post Jul 9 2017, 02:51 PM
Resident Electrician
in the US, 99% of cars have a 7/16"-20 thread pitch for the seatbelt. So you might be able to find any type of vehicle repair nut and make it work.
Mark Henry
post Jul 9 2017, 02:55 PM
that's what I do!
VW aircooled bug shop.
Mike Bellis
post Jul 9 2017, 02:57 PM
Here's a repair piece...
http://www.ebay.com/itm/2-Seat-Belt-Bungs-...a99&vxp=mtr
Rand
post Jul 9 2017, 03:32 PM
Cross Member
Do you have a bolt that threads into it? If so, take it to your local hardware store and find a nut that fits.
Mark Henry
post Jul 9 2017, 04:03 PM
that's what I do!
I forget the pitch, but IIRC it's an oddball, you could try Fastenal or Bell metric.
That said I'm pretty sure about a bug shop having the repair bit. 914 has the same hardware as a 70's bug.
Mark Henry
post Jul 9 2017, 04:08 PM
that's what I do!
cip1 sells these, I thought they would be metric (IMG:style_emoticons/default/confused24.gif)
http://www2.cip1.com/ProductDetails.asp?Pr...ode=C27-SEC6814
http://www2.cip1.com/ProductDetails.asp?Pr...e=C45-20304-SET
Rand
post Jul 9 2017, 04:15 PM
Cross Member
Or if you are replacing it anyway, find a standard but appropriate bolt and nut pair at your hardware store. Not even a CCW would catch it. (I hear the voices of purists talking about tensile strength, yada. Buy quality hardware. I just hate it when there are super specialized parts that don't need to be.)
Mark Henry
post Jul 9 2017, 04:19 PM
that's what I do!
QUOTE(Mike Bellis @ Jul 9 2017, 04:51 PM) *
You're right! Even on euro cars, due to US mandated standards.
I didn't know that. (IMG:style_emoticons/default/popcorn[1].gif)
Here's a C&P from the samba
rsxsr wrote:
Seatbelts use a unique bolt. It is a strong grade and odd thread pitch so that you can't accidentally put in cheap hardware.
7/16" SAE fine-thread grade 8 bolt/nut are utilized
throughout the North American Vanagon Seat Belt system...
Kinda weird on a metric built automobile....
Metric bolts and nuts get close to fitting but are a NO-GO.
The 7/16" SAE fine thread grade 8 stuff works 100%. Wink
So far in my searches.. I have not located a square nut in this size?... I've used hex nuts in my repairs of this ongoing problem.
Begs the question: are European Transporters using this SAE
bolt system on the seat-belts?
Pz
I can't say for sure, but probably so. the US safety standard FMVS209 stipulates the size of 7/16-20 or equivalent. So you will find this same size on many non-US cars - European and Asians ones too, at least on models heading to the US. I suspect that many non-US models still use the 7/16-20 size as well.
The Asians ones seem to "cheat" - but just by a hair, literally. My measurements indicates they are probably using M11-1.25 - only about 0.003" difference. (Note, not really cheating - it is equivalent)
Strength is indeed grade 8 which is the same as the metric property class 10.9 (150,000 psi / 1040 MPa - same hardness of HRC 33-39), so some of the European companies put 10.9 on the head.
GM switched to M12-1.75 seat belt bolts several years back, but their global spec is 7/16-20 now - per the request of their non-US divisions!
amfab
post Jul 10 2017, 09:26 AM
You guys all rock!
Thank you
- Lo-Fi Version Time is now: 30th June 2025 - 10:20 PM
