QUOTE(Mike Bellis @ Jul 9 2017, 04:51 PM)
in the US, 99% of cars have a 7/16"-20 thread pitch for the seatbelt. So you might be able to find any type of vehicle repair nut and make it work.
You're right! Even on euro cars, due to US mandated standards.
I didn't know that.
Here's a C&P from the samba
rsxsr wrote:
Seatbelts use a unique bolt. It is a strong grade and odd thread pitch so that you can't accidentally put in cheap hardware.
7/16" SAE fine-thread grade 8 bolt/nut are utilized
throughout the North American Vanagon Seat Belt system...
Kinda weird on a metric built automobile....
Metric bolts and nuts get close to fitting but are a NO-GO.
The 7/16" SAE fine thread grade 8 stuff works 100%. Wink
So far in my searches.. I have not located a square nut in this size?... I've used hex nuts in my repairs of this ongoing problem.
Begs the question: are European Transporters using this SAE
bolt system on the seat-belts?
Pz
I can't say for sure, but probably so. the US safety standard FMVS209 stipulates the size of 7/16-20 or equivalent. So you will find this same size on many non-US cars - European and Asians ones too, at least on models heading to the US. I suspect that many non-US models still use the 7/16-20 size as well.
The Asians ones seem to "cheat" - but just by a hair, literally. My measurements indicates they are probably using M11-1.25 - only about 0.003" difference. (Note, not really cheating - it is equivalent)
Strength is indeed grade 8 which is the same as the metric property class 10.9 (150,000 psi / 1040 MPa - same hardness of HRC 33-39), so some of the European companies put 10.9 on the head.
GM switched to M12-1.75 seat belt bolts several years back, but their global spec is 7/16-20 now - per the request of their non-US divisions!
