motor mount difference between 911 and 914 style |
jimkelly |
Jul 13 2017, 09:58 AM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
http://www.autoatlanta.com/Porsche-914-Mot...ounts-srch.html
is there a difference in height or thickness from the 911 mount vs the 914 mount of this style? thanks (IMG:style_emoticons/default/smile.gif) Attached image(s) |
gms |
Jul 13 2017, 11:02 AM
Advanced Member Group: Members Posts: 2,695 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
I put them on my 914/6 as trans mounts as I recall all I had to do was to hog out the 2 side mounting holes with a step drill bit.
stownsen914 |
Jul 13 2017, 11:50 AM
Senior Member Group: Members Posts: 913 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
I believe the 914 mounts are substantially softer, so your engine/trans will move around more than with 911 mounts, for what it's worth.
Scott |
SirAndy |
Jul 13 2017, 11:54 AM
Resident German Group: Admin Posts: 41,658 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
The 911 sport mounts are the same thickness but you may have to hone out the mounting holes a bit (i never had to).
Just be aware that they are only "motor" mounts for early tail shifter cars. On the later side shifter cars, they can only be used as a replacement for the rear transmission mounts. (IMG:style_emoticons/default/shades.gif) |
jimkelly |
Jul 13 2017, 03:09 PM
because on the later cars the side shift engine bar is mounted solidly to the car.
thanks jim The 911 sport mounts are the same thickness but you may have to hone out the mounting holes a bit (i never had to). Just be aware that they are only "motor" mounts for early tail shifter cars. On the later side shifter cars, they can only be used as a replacement for the rear transmission mounts. (IMG:style_emoticons/default/shades.gif) |
Steve |
Jul 13 2017, 03:42 PM
914 Guru Group: Members Posts: 5,597 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I think the rear 914-4 ones had holes through the rubber versus a six looks like the one pictured above
flmont |
Jul 13 2017, 06:18 PM
Senior Member Group: Members Posts: 879 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region |
I was actually going to ask if the 911 mount's,..the 20.00 version from pelican were strong enough to hold the EG33 weight or should I hard mount it to the chassis with a plate,..Iam using the EG33 engine mount's as it is,.but Brody from 914 gone wild suggested I use both a while back ???
jimkelly |
Jul 13 2017, 07:21 PM
i plan to use 911 mount and these 2 oem 914 washers at all four corners.
Attached image(s) |
flmont |
Jul 13 2017, 07:46 PM
Ahh Ok Ill look in to that ...Thanks
GeorgeRud |
Jul 13 2017, 08:19 PM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
The 911 mount will work as described. The original -6 mounts were stiffer than those on the -4s because of the lack of the holes in the mount.
Dave_Darling |
Jul 14 2017, 09:30 AM
914 Idiot Group: Members Posts: 14,990 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
I was actually going to ask if the 911 mount's,..the 20.00 version from pelican were strong enough to hold the EG33 weight or should I hard mount it to the chassis with a plate,..Iam using the EG33 engine mount's as it is,.but Brody from 914 gone wild suggested I use both a while back ??? Four of the 911 mounts hold the ~500 lb 911 engine and ~125 lb transmission in the 911 shell. You'll have to decide if that's strong enough for your purpose. --DD |
gms |
Jul 14 2017, 09:41 AM
I just saw the mounts for sale on Pelican .
You will also need the cupped washer that goes over the top of the 911 mount as the OEM 914 part will not work so well. |
gms |
Jul 14 2017, 09:53 AM
901-305-311-00
they look like this |
Andyrew |
Jul 14 2017, 10:37 AM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
911 sport mounts for the trani (What you have pictured) also require the small holes to be ovaled just a hair, about 1/16" to bolt up.
jimkelly |
Jul 14 2017, 11:48 AM
it's always something (IMG:style_emoticons/default/smile.gif)
so it looks like 2ea of this washer for each mount is best, pn: 90130531100 are they big enough to hold engine off the floor if rubber mounts fails? seems like all these metal washers, regardless of style, the mounts loses most of its flexibility (IMG:style_emoticons/default/idea.gif) jim Attached image(s) |
BillC |
Jul 14 2017, 12:19 PM
Senior Member Group: Members Posts: 542 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region |
it's always something (IMG:style_emoticons/default/smile.gif) so it looks like 2ea of this washer is best, pn: 90130531100 are they big enough to hold engine off the floor if rubber mounts fails? seems like all these metal washers, regardless of style, the mounts loses most of its flexibility (IMG:style_emoticons/default/idea.gif) jim Yes, those washers will work. However, you'll four of them, one above and one under each mount. The mounts are designed to work with those washers. The mounts actually aren't supposed to have a lot of flexibility. Their primary purpose is to isolate vibration, without letting the engine/trans "float" around too much. |
gms |
Jul 14 2017, 12:26 PM
are they big enough to hold engine off the floor if rubber mounts fails? seems like all these metal washers, regardless of style, the mounts loses most of its flexibility (IMG:style_emoticons/default/idea.gif) These mounts will be more firm and due to the design of the mount it would be near impossible for the washer to fall thru it. |
mepstein |
Jul 14 2017, 12:34 PM
914-6 GT in waiting Group: Members Posts: 19,294 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I wouldn't buy used. The new ones aren't that expensive. If you are buying more than one pair, I'll find you a good price.
jimkelly |
Jul 14 2017, 12:40 PM
thanks guys (IMG:style_emoticons/default/bye1.gif)
yup, seems best to buy mounts and washers new. thanks. my plan is to use one 911 mount at each of the four corners. jim Attached image(s) |
11tenths |
Jul 14 2017, 05:17 PM
Ve get too soon old, und too late schmart Group: Members Posts: 142 Joined: 11-October 12 From: Islip, Long Island, NY Member No.: 15,026 Region Association: North East States |
Lo-Fi Version | Time is now: 27th May 2024 - 11:29 AM |
