#8 nose bearing coatings or replace? -6 |
mb911 |
Jul 14 2017, 02:45 PM
914 Guru Group: Members Posts: 6,820 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
mb911 |
Jul 14 2017, 02:59 PM
I do see they are anywhere from 145 to 250 for the bearing.
Jul 14 2017, 04:00 PM
914-6 GT in waiting Group: Members Posts: 19,254 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Yikes, retail sucks (IMG:style_emoticons/default/biggrin.gif)
mb911 |
Jul 14 2017, 04:19 PM
Thanks Mark for helping out.. I really appreciate it..
Front yard mechanic |
Jul 14 2017, 07:09 PM
Senior Member Group: Members Posts: 1,157 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
US Chrome
Mark Henry |
Jul 14 2017, 07:28 PM
Mark Henry |
Jul 14 2017, 07:35 PM
Those are all used, but within spec bearings, I DFL (dry film lube) coated them.
It works good but it won't repair scratches, etc. It also won't bring an out of spec bearing back into spec, it's only about .0002-.0004 thick. |
mb911 |
Jul 15 2017, 06:44 AM
Thanks guy's.. Mark is that sprayed on and then baked? Either way I am good to go now. I have the super expensive 1st under main bearings with number 8 being standard that Mark Epstein found me. Thanks again.
Mark Henry |
Jul 15 2017, 09:42 AM
Thanks guy's.. Mark is that sprayed on and then baked? Either way I am good to go now. I have the super expensive 1st under main bearings with number 8 being standard that Mark Epstein found me. Thanks again. You have to clean, light blast it with a special dedicated media, spotless clean, spray and bake at exactly a certain temp (+/-5F). Not too bad if you follow the procedure to the letter, ceramic coatings are a lot harder to get right. Stock 930 pistons with DFL skirts and ceramic coated tops: (IMG:http://www.914world.com/bbs2/uploads/post-26-1393853604.jpg) |
mb911 |
Jul 25 2017, 11:13 AM
Thanks Mark E for sending me a new spare nose bearing.. I really appreciate
Lo-Fi Version | Time is now: 3rd May 2024 - 06:47 PM |
