FS extremely well built race car, FS extremely well built race car |
john914somers |
Jul 16 2017, 07:02 AM
Member Group: Members Posts: 59 Joined: 24-January 12 From: sacramento Member No.: 14,051 Region Association: Northern California |
Divorce forces sale!!!
I have a no expense spared racing prepared 914 rolling chassis. Rotisserie - every nut and bolt off preparation. Taken down to the metal, all seam sealer removed, epoxy primer, POR-15 undercoating on bottom and in fender wells, custom paint, fiberglass fenders 5" fronts, 9" rears will accommodate 17x9" and 17x11" wheels (as pictured), Fiberglass panels trunk and hood, custom aluminum top, custom front air dam, Porsche cup car carbon fiber wing, lexan windshield, custom aluminum fuel cell, custom dual master brake cylinders with in-cockpit real time adjuster, Patterson dry sump, dyna-flow oil cooler, 8-point Tangerine Racing roll cage, chrome moly shock tower supports, 6 point harness, Tangerine racing chassis stiffening kit, Tangerine Racing 1" hardened chrome moly fully adjustable sway bar, Tangerine Racing rear shock tower raising kit, custom adjustable camber plates, 23 mm torsion bars, 300 lbs rear coils with adjustable perches and new bilstien shocks, 5 bolt 911 all the way around, Brembo 928 turbo front brakes, PMB Performance Brembo rear aluminum calipers, automotion gauges, $1,100 racing seat (can't remember the brand but purchased at Sonoma raceway, so quality seat), proper kill switch, fire system (still current), convex racing rear view mirror, Porsche quick disconnect steering wheel, lap timer/Computors. This chassis is super light, all excess weight was removed, NEVER wrecked, no bondo, except to mold the flares. I had a 3.2 and 901 in it then put a 3.6 and 915 in it... very fast, very fun. Comes with Turbo Twist wheels, pictured with Fikse wheels. Thierry has been no expense spared on this car and was extremely well done! I have well over 30K into this, will sacrifice for $10,000. |
john914somers |
Jul 18 2017, 10:24 PM
This is a California car, absolutely 100% rust free and no bondo, except where the the flairs were molded in. This car has been meticulously built! All you need is the engine-tranny of your choice. Everything else is A+ grade!
Lo-Fi Version | Time is now: 22nd May 2024 - 04:42 PM |
