calling engine rebuilders, looking for your input on these bearings, 2.2T 6-cyl |
Optimusglen |
Jul 17 2017, 07:23 AM
Senior Member Group: Members Posts: 901 Joined: 26-February 16 From: Minneapolis Member No.: 19,709 Region Association: Upper MidWest |
First, read this carefully. I'm not going to re-use the bearings. Never planned on it. I am just looking for input on condition and wear patterns.
This past weekend I was able to split the case on a 2.2T engine I am rebuilding for my 914. So far the tear down has been great, nothing broken, no chunks of metal or debris, everything came apart without much fuss, and the case has time-serts. Case is apart now, most of the bearings looks really good, a few have some wear. I've had a few engines apart but not many, and those were special circumstances so I don't have a lot of personal experience reading wear on bearings. One case half (IMG:http://www.914world.com/bbs2/uploads_offsite/c1.staticflickr.com-19709-1500297820.1.jpg) From one end to the other, close up's on each of them (IMG:http://www.914world.com/bbs2/uploads_offsite/c1.staticflickr.com-19709-1500297820.2.jpg) This one seems to have much more wear than all of the others for the crank. (IMG:http://www.914world.com/bbs2/uploads_offsite/c1.staticflickr.com-19709-1500297820.3.jpg) The dark spot here is oil. (IMG:http://www.914world.com/bbs2/uploads_offsite/c1.staticflickr.com-19709-1500297821.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/c1.staticflickr.com-19709-1500297821.5.jpg) Wear on the far edge of this one. (IMG:http://www.914world.com/bbs2/uploads_offsite/c1.staticflickr.com-19709-1500297821.6.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/c1.staticflickr.com-19709-1500297821.7.jpg) For the intermediate shaft bearings: (IMG:http://www.914world.com/bbs2/uploads_offsite/c1.staticflickr.com-19709-1500297821.8.jpg) More wear here too. (IMG:http://www.914world.com/bbs2/uploads_offsite/c1.staticflickr.com-19709-1500297821.9.jpg) Any thoughts or input from you guys and gals? The engine was a core, unknown history. Buying it was a roll of the dice. |
Luke M |
Jul 17 2017, 11:36 AM
Senior Member Group: Members Posts: 1,369 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
I've had several 911 engines apart. from 2.0 to 3.2.. Some engines had bearings that looked like yours and some worse. You should be good to go with new bearings for most part. There was an issue with the bearings (mains and rods) being made in Brazil. If you can find the ones " made in Germany " you'll be better off. I searched for a while and found a dealer in the NE which provided me with the bearings for my brothers 3.0 .
I do not have the info handy but once I find it I can post it here or pm it to you. The case through stud on the lay shaft should have a case saver installed if not already done. You will want to do that prior to having the case cleaned. |
Lo-Fi Version | Time is now: 28th April 2024 - 02:27 PM |
