914 stock stub axle - dimension? |
jimkelly |
Jul 17 2017, 11:38 AM
anyone have a 914 stub axle laying around?
i was wondering what the OD is of the splined area. i'm thinking of using a second stub axle bolted to main stub axle and having the second splined to fit this vw splined flange that is type1 to type2/4 (924/944 100mm cv), for wheel side. or simply turn down the stub axle so the flange can simply be welded to it. this would make the trans side and wheel side easy, but simply needing welding, after cutting and lathing. pair of 924 axles $150 DTA brand on ebay. 4 flanges $35 x 4ea = $140 924 axles are 16.125" AND 944 AXLES ARE ?" http://www.blindchickenracing.com/how_to/c...s/axles_101.htm Attached image(s) |
Phoenix-MN |
Jul 17 2017, 12:05 PM
Senior Member Group: Members Posts: 927 Joined: 23-January 04 From: ST. Bonifacius,MN Member No.: 1,590 |
anyone have a 914 stub axle laying around? i was wondering what the OD is of the splined area. i'm thinking of using a second stub axle bolted to main stub axle and having the second splined to fit this vw splined flange that is type1 to type2/4 (924/944 100mm cv), for wheel side. 30mm 37 spline, ya doing something like this? |
jimkelly |
Jul 17 2017, 12:13 PM
that is exactly what i was thinking (IMG:style_emoticons/default/smile.gif)
is yours a 108mm flange or 100mm? my flange has a 26mm ID where the splines are. |
Phoenix-MN |
Jul 17 2017, 12:15 PM
108mm
jimkelly |
Jul 17 2017, 12:19 PM
thanks again (IMG:style_emoticons/default/beerchug.gif)
Phoenix-MN |
Jul 17 2017, 12:21 PM
jimkelly |
Jul 17 2017, 12:31 PM
for ONE SECOND i thought i was the most ingenious mother fucker around. well, it felt good while it lasted (IMG:style_emoticons/default/biggrin.gif)
Phoenix-MN |
Jul 17 2017, 12:40 PM
" Great minds think alike "
jimkelly |
Jul 17 2017, 12:51 PM
i assume a stub axle can be turned on a lathe?
or are they TOO HARD? |
Phoenix-MN |
Jul 17 2017, 01:10 PM
I took a file to the splines and they seem to cut pretty easy
jimkelly |
Jul 17 2017, 02:59 PM
my thought is that with everyone saying that when cutting and resplining a stock 914 axle to use with a suby cv at trans and 914 cv at wheel, that there is practically no margin for error on length, that two flanges and a 924 or 944 axle assy has got to be more forgiving, and stronger too.
are you bolting the two stub axles together or welding them together? is your flange attached using the splines or is your flange going to be welded to the innermost stub axle? i am leaning towards welding it all together. |
Phoenix-MN |
Jul 18 2017, 06:59 AM
my thought is that with everyone saying that when cutting and resplining a stock 914 axle to use with a suby cv at trans and 914 cv at wheel, that there is practically no margin for error on length, that two flanges and a 924 or 944 axle assy has got to be more forgiving, and stronger too. are you bolting the two stub axles together or welding them together? is your flange attached using the splines or is your flange going to be welded to the innermost stub axle? i am leaning towards welding it all together. my plan is to bolt them together using the two 10mm roll pins, the flange will be attached using the splines with a washer and snap ring. I'll be cutting the threaded end of the stub axle off. |
Andyrew |
Jul 18 2017, 10:26 AM
That seams like WAY to much work. To many fail points IMHO If your going through all that work why not just mill up some adapters?
The way I have mine setup is 100mm adapters on the wheel side stub, VW Bus (100mm) axles, commonly used up to 500hp, then 100mm stub axle in the trani. Bolts right in on my setup (Because I centered the trani) I dont even have to have custom axle shaft lengths. Just right out of the box axles. |
Olympic 914 |
Jul 18 2017, 01:14 PM
Group: Members Posts: 1,672 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
I am not an engineer but wouldn't moving the CV joint in that far increase the angle it has to work at?
Or is it still within its operating range. I had heard of people blowing CV joints coming hard out of a parking lot and such. (IMG:style_emoticons/default/confused24.gif) |
jimkelly |
Jul 18 2017, 03:38 PM
andyrew, did you mill the wheel side adaptors? or does someone sell them for 100mm cvs?
and yes, i am a little concerned with using 924 axles that are only 16-1/8" length vs 944 which i think are about 2" longer. 914 axles are 21.25" long i think. |
Andyrew |
Jul 18 2017, 04:34 PM
Renegade Hybrids "500HP" axle conversion is billet aluminum adapters on both sides with VW Bus axles. I bought them from a member used and only used one side the adapter. I have the others attached to two spare CV's I bought for $80ea with some spare 914 stub axles. I doubt I'll ever need them but if I ever break one I can swap it in in 20 mins.
Lo-Fi Version | Time is now: 26th May 2024 - 11:12 PM |
