Rebuilding Throttle Bodies, New service. No more sticky throttle! |
Bartlett 914 |
Jul 17 2017, 06:22 PM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
Recently I got tired of my sticky uneven throttle body. I was stuck in construction traffic and inching forward became almost impossible. I decided to repair mine. The throttle body shaft has no bearing. It is steel against aluminum. In time the round hole becomes an oval one. This makes the throttle plate operate erratically. It even sticks when in the closed position.
I made a setup in my machine shop to repair these. I accurately locate the shaft hole and boar it to fit an oilite bushing. I have done a dozen of these so far. In my car, the difference was incredible. I expected the operation off idle to be improved which it did but I also found the operation was smoother through the operating range. I decided I could offer this as a service. In this, I will clean the body and install the new bushings. This operation requires special machining in order to keep things aligned properly. At this point, I am not plating anything. I am only cleaning the steel components. I may offer plated parts later but not at this time. I will need a core in exchange for one I send out or I can repair yours but there will be a delay in doing this. There are some that have 2 ports and some with only one. Some have a built in return spring and the other does not. You can see the differences in the ones pictured. If you are interested in this service, My starting price is $125.00 plus shipping |
solex |
Jul 29 2017, 12:03 PM
Senior Member Group: Members Posts: 789 Joined: 12-January 05 From: Long Island, NY Member No.: 3,439 Region Association: North East States |
Installed the TB today set the TPS, Dwell and Idle.
Now I have to get used to not expecting the throttle initially sticking. Thanks Mark New bronze bushing My attempt to grease the original throttle shaft a while ago Top shot of the new throttle body |
euro911 |
Jul 29 2017, 02:21 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,849 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Installed the TB today set the TPS, Dwell and Idle. Is that like remembering exactly where there's a scratch in a song on vinyl LP album?Now I have to get used to not expecting the throttle initially sticking. ... ... (IMG:http://www.914world.com/bbs2/uploads_offsite/media.giphy.com-7300-1501359711.1.gif) |
Lo-Fi Version | Time is now: 15th May 2024 - 03:09 AM |
