is there a BEST raddle can primer, engine bay primer |
flmont |
Jul 19 2017, 03:02 PM
Senior Member Group: Members Posts: 879 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region |
I am about to get my engine bay blasted with the dustless blasting system on Saturday,.and of course want to primer it fairly quick,..do they make a good raddle can primer or should I go with a primer I need to mix and spray , ?? Thanks Frank
solex |
Jul 19 2017, 03:16 PM
Senior Member Group: Members Posts: 789 Joined: 12-January 05 From: Long Island, NY Member No.: 3,439 Region Association: North East States |
I have used VHT Self Etching Primer with excellent results on aluminum rims.
https://www.amazon.com/VHT-SP307-Performanc...r/dp/B003BGYRPO |
Tom_T |
Jul 19 2017, 03:29 PM
TMI.... Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
I would say to use Wurth or Eastwood High Zinc content weld thru primer in cans to give the benefits which a zinc hot dip would've done if they did that back at the factory (never on 914s, but 76> they did for the other P-cars).
I think that whenever you're ready to paint, then you can prime with a 2-part epoxy primer/etc. over it, but the zinc primer will protect the bare metal. I've used the Wurth one on all of the body & part surfaces on my 73, as I've gone thru & wire wheeled off the surface rust areas, to "freeze" any further damage. (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
dlee6204 |
Jul 19 2017, 04:00 PM
Howdy Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
There's no way I would spend the time and money to have my car blasted only to cover it up with a rattle can primer.
Two part primer is the way to go. |
mgphoto |
Jul 19 2017, 04:34 PM
"If there is a mistake it will find me" Group: Members Posts: 1,337 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
I would say to use Wurth or Eastwood High Zinc content weld thru primer in cans to give the benefits which a zinc hot dip would've done if they did that back at the factory (never on 914s, but 76> they did for the other P-cars). I think that whenever you're ready to paint, then you can prime with a 2-part epoxy primer/etc. over it, but the zinc primer will protect the bare metal. I've used the Wurth one on all of the body & part surfaces on my 73, as I've gone thru & wire wheeled off the surface rust areas, to "freeze" any further damage. (IMG:style_emoticons/default/beerchug.gif) Tom /////// What ever you do don't use weld thru primer as a base, it doesn't have any binders in it, once dry you can remove it by wiping with paint thinner. Best to use a epoxy 2 part Southern polyurethanes hot rodders love the stuff, me too. |
flmont |
Jul 19 2017, 04:36 PM
Yea,..I know, But its humid here in Tucson,..( monsoon season)and I don't want surface rust.so I thought if I could find a good primer in a spray bomb why not whats the diffrence are they not mixed the same as the 2 part product..
flmont |
Jul 19 2017, 05:04 PM
Yea its no problem to stop at the paint store,.and Iam sure that is the smartest thing to do,..Thanks
mzalanka |
Jul 19 2017, 05:15 PM
Member Group: Members Posts: 116 Joined: 11-July 11 From: Portland, OR Member No.: 13,300 Region Association: None |
100% do 2-part epoxy.
You can get it in a rattle can, with the little button on the bottom to activate. |
Costa05 |
Jul 19 2017, 05:28 PM
Member Group: Members Posts: 320 Joined: 27-October 16 From: Phoenix, Arizona Member No.: 20,535 Region Association: Southwest Region |
Yea its no problem to stop at the paint store,.and Iam sure that is the smartest thing to do,..Thanks I have been shooting two or three coats of Matrix Epoxy Primer as my base over sanded prepped surface or bare metal. Even shot it over areas that I did rust conversion on. Does not come in a rattle can but is fairly easy to spray with inexpensive spray settup and just like all paints wear a good mask as it is very toxic to breath. You should let it dry for several days too so all the solvents can release. |
flmont |
Jul 19 2017, 05:35 PM
You can get it in a rattle can, with the little button on the bottom to activate. where would you get such a product ,auto paint store |
flmont |
Jul 19 2017, 05:37 PM
wish I knew how to use the quote button
dlee6204 |
Jul 19 2017, 05:42 PM
100% do 2-part epoxy. You can get it in a rattle can, with the little button on the bottom to activate. where would you get such a product ,auto paint store Eastwood... http://www.eastwood.com/eastwood-s-2k-aero...gray-black.html |
mgphoto |
Jul 19 2017, 05:43 PM
flmont |
Jul 19 2017, 06:27 PM
isn't that the damnedest thing, Thanks !!
burton73 |
Jul 19 2017, 10:40 PM
burton73 Group: Members Posts: 3,510 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
I used some DuPont Epoxy in rattle can. Get 6 at a time in tall cans at Auto Paint store. Price is not bad.
Bob B |
Lo-Fi Version | Time is now: 2nd May 2024 - 05:35 PM |
