is there a BEST raddle can primer, engine bay primer |
flmont |
Jul 19 2017, 03:02 PM
Senior Member Group: Members Posts: 879 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region |
I am about to get my engine bay blasted with the dustless blasting system on Saturday,.and of course want to primer it fairly quick,..do they make a good raddle can primer or should I go with a primer I need to mix and spray , ?? Thanks Frank
Tom_T |
Jul 19 2017, 03:29 PM
I would say to use Wurth or Eastwood High Zinc content weld thru primer in cans to give the benefits which a zinc hot dip would've done if they did that back at the factory (never on 914s, but 76> they did for the other P-cars).
I think that whenever you're ready to paint, then you can prime with a 2-part epoxy primer/etc. over it, but the zinc primer will protect the bare metal. I've used the Wurth one on all of the body & part surfaces on my 73, as I've gone thru & wire wheeled off the surface rust areas, to "freeze" any further damage. (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
mgphoto |
Jul 19 2017, 04:34 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
I would say to use Wurth or Eastwood High Zinc content weld thru primer in cans to give the benefits which a zinc hot dip would've done if they did that back at the factory (never on 914s, but 76> they did for the other P-cars). I think that whenever you're ready to paint, then you can prime with a 2-part epoxy primer/etc. over it, but the zinc primer will protect the bare metal. I've used the Wurth one on all of the body & part surfaces on my 73, as I've gone thru & wire wheeled off the surface rust areas, to "freeze" any further damage. (IMG:style_emoticons/default/beerchug.gif) Tom /////// What ever you do don't use weld thru primer as a base, it doesn't have any binders in it, once dry you can remove it by wiping with paint thinner. Best to use a epoxy 2 part Southern polyurethanes hot rodders love the stuff, me too. |
Lo-Fi Version | Time is now: 17th May 2024 - 03:03 PM |
