Standalone Gas Gauge, small replacement |
mmascari |
Jul 19 2017, 08:10 PM
Member Group: Members Posts: 321 Joined: 1-September 14 From: Concord, CA Member No.: 17,850 Region Association: None |
Can someone recommend a small standalone gas gauge that is compatible with the stock fuel sender. I am doing a six conversion and replacing the left gauge with a 911 style oil pressure/temp gauge.
Montreal914 |
Jul 19 2017, 08:20 PM
Senior Member Group: Members Posts: 1,545 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
I have been successfully using a 2 1/16" VDO gauge that I got on the samba for 10$, took a guess and got lucky (IMG:style_emoticons/default/rolleyes.gif) .
That being said, here is the info you want as far as the sender which is what you need to rely on when getting your new gauge; http://www.914world.com/bbs2/index.php?sho...p;hl=fuel+gauge Good luck and let us know where you intend to install it. I have mine in the center console and have used electric tape to build up the diameter to fit the rubber sleeve. |
Lo-Fi Version | Time is now: 8th May 2024 - 05:41 AM |
