914-6 GT oil system |
dug |
Jul 20 2017, 07:40 PM
Member Group: Members Posts: 182 Joined: 26-December 06 From: Santa Cruz, CA Member No.: 7,382 Region Association: Northern California |
Try to find all these parts to match my price.
You can't. You won't. I dare you! I've been to that place and you don't want to go there. Just buy mine and you will have the complete setup, no waiting! 914-6 Oil tank (new - Porsche) GT Oil tank filler neck 80mm - press bypass fitting - repro (Sierra Madre) GT Oil tank filler cap 80mm - Blau aluminum outer, steel inner, with fin GT Oil filter console - early 911S magnesium GT Oil filter console spacer - repro (Barry Pantzer) 100mm allen head bolts - new zinc plated steel GT Oil thermostat - cast with mounting tab and 26mm ports 26mm-26mm male fittings (2) 26mm-30mm male fittings (1) 20mm-26mm male fittings (2) GT Oil pressure relief valve - aluminum repro (JKH) GT Oil lines to front cooler - brass repro (JKH) GT Oil line solid T-tank-return-pressure relief - repro (JKH) GT Flex oil line hose - 26mm new (Cohline) GT Flex oil line hose - 30mm new with green tracer (Elephant) 30mm 90 degree oil line fitting (2) - new (Elephant) 30mm straight oil line fitting (2) - new (Elephant) GT Argus short line GT Oil catch tank (67 912 Washer Bottle) GT Front oil cooler shroud - steel reproduction (mittlemotor) 30mm 90 degree Oil line fitting - used TCH Aluminum 26mm 90 degree Oil line fitting - used TCH Aluminum 26mm 45 degree with 30mm T - steel reproduction (JKH) Red Purolator filter stamped with Porsche I will sell the kit for $9k. Or $8k if you don't need the brand new 914-6 oil tank. Pics posted on bird board here: http://forums.pelicanparts.com/porsche-914...oil-system.html cheers, dug |
rgalla9146 |
Jul 22 2017, 10:38 PM
Advanced Member Group: Members Posts: 4,559 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Any chance of a picture or pictures ?
Lo-Fi Version | Time is now: 20th May 2024 - 03:11 PM |
