Wheel Spacer Req'mt., Joe O'Brien?? |
andys |
May 16 2005, 11:26 AM
A previous thread on "The Final Word" regarding wheel spacers was, well, not so final in some respects. So, at the risk of "Oh no, not again", I thought I'd ask anyway.
My plan is to run the 7" front and 9" rear F'glass GT flares. For wheels, I have the 993 Cup wheels like Joe O'Brien's great looking black powder coated one's, only they're still silver. 205-17 fronts, and 255-40-17 rears. Rear wheels are 9" wide, offset is ET55. What spacer works best for the 9" rear flare/wheel/tire combo? I just need to get in the ball park with a number, as I realize I'll want to fine tune the exact spacing. The car isn't flared yet. I measured the backspacing on the stock wheel (MOMO w/ 195-50-15) at 4 7/8", and the 993 at 7 1/2". The difference is 2 5/8" (66.6mm), so that implies the spacer must be that thickness. Any info would be helpful......Joe, what did you use on your's? I know, I should've asked you at the WCC in Camarillo, but....... Andy |
Joe Bob |
May 16 2005, 11:31 AM
What works best or what will fill the wheel well?
What WORKS is inch up front and 2 inch on the rear based on the typical 964 wheel. This will clear the INNER wheel wells. As to what FILLS the wheel well on the outside....it varies .... the wheel arches vary from manufaucturer to manufacturer, tire size and the fitment of the flares.... My last 914/6 with flares....3 inch spacers, 16x9 964 wheels with GT flares and 255/45/16 tires filled nicely. 2 inch on the fronts with 225/46/16 and 7.5 inch wide wheels.... |
d914 |
May 16 2005, 11:34 AM
I ran a 35mm up front and a 54mm in the back for 16x9 and 16x7 cup wheels with 225 and 245's. or roughly what z said.....
by the way this is me with a broken clutch fork rolling into the pits, many moons ago.. Attached image(s) |
andys |
May 17 2005, 12:21 PM
ttt
Series9 |
May 17 2005, 01:13 PM
100mm wheels studs and 42mm spacers all the way around with steel lugs.
I could go a little more. I'll probably settle on 2"(50.8mm) for all four corners. |
d914 |
May 17 2005, 02:50 PM
that would probably work. I had 35's all around and one side just missed and rubbed on the back. At the time the 54's are what I found and new about. I used the bolt on's at that time. On the fronts they could of used a bit more of a push out.
see pic.. |
Lo-Fi Version | Time is now: 5th May 2024 - 10:31 AM |
