Difficulty shifting, Difficulty shifting |
tsvo |
Jul 22 2017, 09:12 PM
Member Group: Members Posts: 123 Joined: 30-January 16 From: Chicago Member No.: 19,616 Region Association: Upper MidWest |
I have difficulty getting my car to shift smooth. Mostly 1st gear. You have to be very gentle getting it to go in gear. It will grind if you try to shift it fast. Sometimes there is a little trouble with it not going in other gears, but mostly first gear. The clutch point is high and seems fine.
Any suggestions? |
RickS |
Jul 22 2017, 11:16 PM
Senior Member Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
Replace all your shift bushings if you haven't already. When they get old, they get loose and sloppy or disintegrate. Even if the bushings may not be the cause, replacement of worn is always a good idea.
Lo-Fi Version | Time is now: 17th May 2024 - 07:57 PM |
