Difficulty shifting, Difficulty shifting |
tsvo |
Jul 22 2017, 09:12 PM
Member Group: Members Posts: 123 Joined: 30-January 16 From: Chicago Member No.: 19,616 Region Association: Upper MidWest |
I have difficulty getting my car to shift smooth. Mostly 1st gear. You have to be very gentle getting it to go in gear. It will grind if you try to shift it fast. Sometimes there is a little trouble with it not going in other gears, but mostly first gear. The clutch point is high and seems fine.
Any suggestions? |
Mikey914 |
Jul 23 2017, 04:26 AM
The rubber man Group: Members Posts: 12,669 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Replace the bushings they are cheap. The question is do you have the early tail shift or late side shift.
If you have this it's a late Let me know I can hook you up with all the bushings you need, all new. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 17th May 2024 - 08:30 PM |
