How bad is this?, unsupported engine |
ericoneal |
Jul 23 2017, 07:49 PM
Member Group: Members Posts: 320 Joined: 13-August 12 From: Crestwood, KY Member No.: 14,795 Region Association: South East States |
I've been working to replace the throw-out bearing in my transmission and all has been going well until today. Got the transmission removed from the car and supported the rear of the engine with a floor jack. (all jacks stands were being used to hold the car up) Got called away, by kids and family stuff, and discovered tonight that the jack had failed! (I know I know) ANyway, the engine back was sagging about 4-5 inches and was unsupported.
I cant see anything blatantly wrong with the engine mounts up front, is there something I should look for as far as potential damage? Think it will be OK? Neighbors jack stand is under it now.. |
Spoke |
Jul 23 2017, 07:53 PM
Jerry Group: Members Posts: 6,977 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
As long as you didn't twist the engine bar (unlikely) or rip the engine mounts, you should be ok. It likely was a slow drop so no issue like from a snap drop.
ericoneal |
Jul 23 2017, 08:16 PM
Thats what I wanted to hear. Thanks
Jul 23 2017, 09:12 PM
Resident German Group: Admin Posts: 41,606 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
or rip the engine mounts You need to double check the motor mounts. The weight of the engine was only supported by those two small rubber pieces, you want to make SURE they are not cracked now. (IMG:style_emoticons/default/popcorn[1].gif) |
Jul 23 2017, 09:27 PM
I did the same thing the first time I tried that. The rubber engine mounts failed in short order after that, and I had to replace them. That's on a side-shift car; the mount for the tail-shifters is different.
--DD |
IronHillRestorations |
Jul 24 2017, 05:51 AM
This happened to me on my very first clutch job too Eric. Like Dave, I had a front engine mount go bad soon after. If the front rubber mounts have plenty of life in them, you may be OK.
ericoneal |
Jul 24 2017, 08:06 AM
Got it. Will check the mounts if/when I get the transmission back in. Tried with two jackstands, think I need three. Cant keep it stable enough to mate with the engine with only two.
bdstone914 |
Jul 24 2017, 08:35 AM
bdstone914 Group: Members Posts: 4,514 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Got it. Will check the mounts if/when I get the transmission back in. Tried with two jackstands, think I need three. Cant keep it stable enough to mate with the engine with only two. Was this on a tail or side shift car? either way check the motor mounts. The side shift mounts tear easily on their own. If on a side shift car the bar to mount brackets will bend but that is not a big deal. Why not drop the engine while you are this close? Only two bolts and the fuel and electrical connections. |
ericoneal |
Jul 24 2017, 09:04 AM
Its a side shift. I didnt drop the engine because I thought just dropping the transmission would be faster, and it was, until I hit this snag.
I had the engine rebuilt two years ago and dropped them both myself and it was a nightmare. I'm getting another jack tonight and it should go back in easy, I hope. One jack up front, and two on the back mounts, so I can lift it evenly. Will take pictures! |
Jul 24 2017, 09:51 AM
If you have the time to wait, you might consider just replacing the mounts. Pelican has them for $17 each.
Jul 24 2017, 10:49 AM
That's on a side-shift car; the mount for the tail-shifters is different. His profile says he has a '73, which is why i assumed a side-shifter. (IMG:style_emoticons/default/shades.gif) |
ericoneal |
Jul 24 2017, 01:11 PM
iankarr |
Jul 24 2017, 01:28 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,472 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
I've found that all floor jacks leak. Some faster than others. Maybe it's just my luck...but I've always thought they were designed for temporary use. Another reason why they say never to get under a car that's only supported by a jack.
Can't hurt to swap out the mounts. They're a maintenance item anyway. A little tricky to get a wrench over the top of the bolt, but doable. |
Jul 24 2017, 03:18 PM
Ya, I think I will go ahead and replace them. Just support the engine, unbolt, and slip new ones on, right? Yes, but there's no "just" about it. The upper nut on both mounts is a pain in the butt to tighten. I think I remember removing the oil filter (letting it drip overnight) so that I could reach in from the side and actually get my hand and my wrench and/or socket into the correct area. I used my 1/4" drive ratchet, and got basically one click per try out of it. It took quite a while to tighten that thing down... --DD |
Triaddave |
Member Group: Members Posts: 244 Joined: 31-December 03 From: olympia,wa Member No.: 1,478 |
If you get the car running first, and when you shift you hear a clunk, motor mount is sour...ask me how I know.
ericoneal |
Jul 25 2017, 09:13 AM
hmm. I took the engine out summer before last and dont remember those bolts being that bad....
Anyway, transmission is back in as of 12:30AM last night. What a job! Never doing that again. (I lie) All thats left now is the starter motor, shift rod, and clutch cable,etc. Then a quick check of the mounts. Ya, I think I will go ahead and replace them. Just support the engine, unbolt, and slip new ones on, right? Yes, but there's no "just" about it. The upper nut on both mounts is a pain in the butt to tighten. I think I remember removing the oil filter (letting it drip overnight) so that I could reach in from the side and actually get my hand and my wrench and/or socket into the correct area. I used my 1/4" drive ratchet, and got basically one click per try out of it. It took quite a while to tighten that thing down... --DD |
Lo-Fi Version | Time is now: 28th April 2024 - 06:36 AM |
