Muffler Welding..., Stainless to Mild steel? |
ss6 |
Jul 3 2003, 04:41 PM
fun city... Group: Members Posts: 261 Joined: 2-February 03 From: Western Connecticut Member No.: 221 |
I'm going to try to fab a clone of the Flowmaster setup Brad was talking about in an old post
http://www.914world.com/bbs2/index.php?act...7&hl=flowmaster Only it ain't gonna be a clone, whatever that setup (see pic) hooked up to, my headers are a lot closer together. Question is, the muffler is mild steel, and the tubing in the pic appears to be stainless. I didn't think you could weld stainless to mild steel, any experts out there? |
LvSteveH |
Jul 3 2003, 06:51 PM
I put the Poor in Porsche Group: Members Posts: 1,080 Joined: 22-April 03 From: Las Vegas, Nevada Member No.: 600 |
I'm far from an expert, but I believe with the correct welding rod or wire it should work ok. I know mild steel can be welded to 4130 chrome-moly with no problems. I'd check with a welding supply shop for specifics. You could of course just flange both sides rather than welding. Good luck.
Steve |
ChrisFoley |
Jul 3 2003, 09:17 PM
I am Tangerine Racing Group: Members Posts: 7,926 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
John,
Its not a problem to weld stainless to mild steel. A special filler wire is required for the strength properties of the weld to be adequate. The joints should be TIG welded with 309 or 309L stainless. |
Lo-Fi Version | Time is now: 19th May 2024 - 09:53 PM |
