Antenna Mounting Template, Fits on single page printer paper |
914Sixer |
Jul 24 2017, 01:59 PM
914 Guru Group: Members Posts: 8,874 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Print it out using regular paper
Attached File(s) scan.pdf ( 497.38k ) Number of downloads: 60 |
ConeDodger |
Jul 24 2017, 02:32 PM
Apex killer! Group: Members Posts: 23,575 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Is that "factoryish" Mark? Just for shits and giggles, I just checked and it pretty much matches mine which I assume to be dealer installed...
914Sixer |
Jul 24 2017, 05:04 PM
Yes it was pulled from a factory Blaupunkt speaker installation kit. I had to highlight the edges from water damage.
rgalla9146 |
Jul 24 2017, 05:49 PM
Not a template but a good reference.
The hard part is finding the original support bracket that attaches to the hole in the pinchweld at the rear of the wheelhouse. I can provide pics if anyone is interested. Attached thumbnail(s) |
Rand |
Jul 24 2017, 06:00 PM
What's an antenna? (IMG:style_emoticons/default/tongue.gif)
Why are people thinking about one now? Never came from the factory. Some dealers did them - that's not a reason to want one, I'd argue it's a reason to NOT want one. With TuneIn, Spotify, IHeartRadio, Pandora, etc., etc., these days, why would you want one today bad enough to cut a hole in your 914 just to get limited range local radio? |
rgalla9146 |
Jul 24 2017, 06:20 PM
I'm just the messinger
boxsterfan |
Jul 24 2017, 06:44 PM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
Seems like there are a lot of other hidden antenna options available vs. cutting a hole in your 914.
Rand |
Jul 24 2017, 06:47 PM
ConeDodger |
Jul 24 2017, 06:52 PM
Seems like there are a lot of other hidden antenna options available vs. cutting a hole in your 914. They have infinite options if they don't want to cut a hole. No brainer. Well... since the hole is already cut in my case, it's interesting that it was probably done with a template. Certainly from a historical POV, I've heard that either side is correct. Looks as if that isn't true. Always looking for information when it comes to the 914. There's no reason to act as if the antenna isn't necessary. There weren't "infinite" options in the 1970's. |
914Sixer |
Jul 24 2017, 07:15 PM
The factory did offer the radio antenna installed in the radio preparation option. No drilling and possibility of paint damage. Dealers used this option to install the aftermarket radio.
Lo-Fi Version | Time is now: 3rd May 2024 - 11:55 PM |
