Bilstein strut insert, Fitment issue |
Aualexa1 |
Jul 24 2017, 05:33 PM
Newbie Group: Members Posts: 45 Joined: 17-June 17 From: South Jersey Member No.: 21,189 Region Association: MidAtlantic Region |
I ordered new Bilstein strut inserts (part number 34-001127-M512) to replace the old Koni's (part number 82R-1730) that I removed from my '73 914. Both inserts should fit a Boge strut, but the new Bilsteins are too tall (about 3 mm longer than the Koni's) and don't fit the strut housing. Any idea what's wrong? Did I order the wrong part?
Attached thumbnail(s) |
914Sixer |
Jul 24 2017, 07:21 PM
914 Guru Group: Members Posts: 8,872 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
If you are talking about the collar not fitting flat against the tube, that is just the way the fit.
Aualexa1 |
Jul 24 2017, 07:27 PM
If you are talking about the collar not fitting flat against the tube, that is just the way the fit. When I put the insert into the strut housing, I can't get the threads to engage in order to screw the insert into the housing. The insert is just a little too high. |
Jul 24 2017, 07:37 PM
914-6 GT in waiting Group: Members Posts: 19,253 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Wrong insert?
Aualexa1 |
Jul 24 2017, 07:40 PM
Here's a picture. The insert fits in the housing, but it bottoms out at the bottom of the housing and won't engage the threads. Can anyone point me to the right part number if this is the wrong one? Thanks in advance.
Alex Attached thumbnail(s) |
914Sixer |
Does this happen on both sides or just one? You may have a bent housing if it only does it on one.
Aualexa1 |
Jul 24 2017, 07:43 PM
Does this happen on both sides or just one? You may have a bent housing if it only does it on one. I checked and it is both sides with both housings and both inserts. When I look in the bottom hole where the ball joint would enter, it looks like the bottom of the strut insert is all the way down and bottomed out. |
Jul 24 2017, 07:45 PM
Can we see a picture of your struts?
Aualexa1 |
Jul 24 2017, 08:01 PM
Aualexa1 |
BillC |
Jul 24 2017, 08:16 PM
Senior Member Group: Members Posts: 536 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region |
This is kind of a long shot, but did you check to make sure the retaining nut fits all the way down on top of the green shock body? Try sliding the nut up and seeing if there's anything trapped under it. I installed a set of those struts a couple of weeks ago, and they dropped right in.
The other possibility is that maybe you have a pair of Koni strut housings. IIRC, they require a slightly different length cartridge than the Boge housings. |
Aualexa1 |
Jul 24 2017, 08:38 PM
This is kind of a long shot, but did you check to make sure the retaining nut fits all the way down on top of the green shock body? Try sliding the nut up and seeing if there's anything trapped under it. I installed a set of those struts a couple of weeks ago, and they dropped right in. The other possibility is that maybe you have a pair of Koni strut housings. IIRC, they require a slightly different length cartridge than the Boge housings. I'm thinking you may be right about the koni strut. How would I tell for sure? If they are Koni's, then the Koni inserts sold on Pelicanparts should fit right (http://www.pelicanparts.com/More_Info/KON86411077SPORT.htm?pn=KON-8641-1077SPORT&catalog_description=Koni%20Sport%20Strut%20Insert%2C%20Front&SVSVSI=5882)? |
bdstone914 |
Jul 24 2017, 10:03 PM
bdstone914 Group: Members Posts: 4,514 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
This is kind of a long shot, but did you check to make sure the retaining nut fits all the way down on top of the green shock body? Try sliding the nut up and seeing if there's anything trapped under it. I installed a set of those struts a couple of weeks ago, and they dropped right in. The other possibility is that maybe you have a pair of Koni strut housings. IIRC, they require a slightly different length cartridge than the Boge housings. I'm thinking you may be right about the koni strut. How would I tell for sure? If they are Koni's, then the Koni inserts sold on Pelicanparts should fit right (http://www.pelicanparts.com/More_Info/KON86411077SPORT.htm?pn=KON-8641-1077SPORT&catalog_description=Koni%20Sport%20Strut%20Insert%2C%20Front&SVSVSI=5882)? They never made Koni struts for a 914. I checked the application and the part number is correct. Sure thee is nothing in the bottom of the strut housing? Note the locatiing nub on the bottom of the Koni ? |
porschetub |
Jul 25 2017, 12:03 AM
Make sure they are seated right @ the bottom,recently fitted Boge/Sachs and they were out buy a turn or 2 but weren't going anywhere after I did them up,no issues after driving.
Sound a little strange the situation you have (IMG:style_emoticons/default/confused24.gif) . |
Mark Henry |
Jul 25 2017, 05:58 AM
Make sure they are seated right @ the bottom,recently fitted Boge/Sachs and they were out buy a turn or 2 but weren't going anywhere after I did them up,no issues after driving. Sound a little strange the situation you have (IMG:style_emoticons/default/confused24.gif) . (IMG:style_emoticons/default/agree.gif) same with Bilstein's most of the time the nut will sit 1-2mm proud. Once you have it figured out don't forget to drop about 1 to 1-1/2oz of oil into the strut before installing the insert. This is mainly to stop corrosion, but it also helps to cool the strut. |
Jul 25 2017, 06:08 AM
Make sure they are seated right @ the bottom,recently fitted Boge/Sachs and they were out buy a turn or 2 but weren't going anywhere after I did them up,no issues after driving. Sound a little strange the situation you have (IMG:style_emoticons/default/confused24.gif) . (IMG:style_emoticons/default/agree.gif) same with Bilstein's most of the time the nut will sit 1-2mm proud. Once you have it figured out don't forget to drop about 1 to 1-1/2oz of oil into the strut before installing the insert. This is mainly to stop corrosion, but it also helps to cool the strut. Bilstein no longer recommends oil in the strut housing but I did spray a little in mine for corrosion resistance. |
BillC |
Jul 25 2017, 07:13 AM
The other thing is to check the bottom of the strut cavity. Since the Konis you removed are shorter than the new Bilsteins, maybe whoever installed them put spacers in the bottom to make the Konis fit properly.
McMark |
Jul 25 2017, 08:06 AM
Your Bilstein part number matches up with what my supplier lists for a 914-4.
When I loaded the full size picture, it looks like there is the end of a part number here, obscured by the undercoating that's all over. Did I miss the part where you mention if this is a 4- or 5-lug strut? Attached image(s) |
Jul 25 2017, 08:39 AM
It looks to have a straight arm so that would be a 4
Tom_T |
Jul 25 2017, 10:44 AM
Double check the part no. on the struts you got (insert bodies & box nos. should match the correct p/n ordered - Bruce confirmed ordered p/n was correct already), since they may have shipped the wrong ones to you (poor pick-n-pak at the DC).
Any of the Boge/Sachs, Koni or Bilstien inserts made for the OE Black/Gray Boge 914-4 Struts should be plug-n-play, as noted by BillC above. (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
Lo-Fi Version | Time is now: 2nd May 2024 - 10:27 AM |
