Identification Help, Speedo, clutch. Accel, etc |
mmascari |
Jul 25 2017, 10:30 PM
Member Group: Members Posts: 321 Joined: 1-September 14 From: Concord, CA Member No.: 17,850 Region Association: None |
My car was apart when I purchased it and now that I am putting things back together I could use some help in identifying how to route cables. Thanks.
Attached thumbnail(s) |
Krieger |
Jul 25 2017, 11:15 PM
Advanced Member Group: Members Posts: 4,705 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
1 and 3 are for your heater valves
2 not sure 4 throttle cable 5 speedo cable 6 clutch cable |
ndfrigi |
Jul 25 2017, 11:54 PM
#2 for the small plastic tube for Charcoal canister.
Frankvw |
Jul 26 2017, 03:01 AM
working on my first 914 ! Group: Members Posts: 651 Joined: 13-April 16 From: Holland, the Netherlands Member No.: 19,896 Region Association: Europe |
If that pic is from your car, then fix the nr6 now when you have easy access to this area. nr 2 has overspray and can easily be replaced by a new grommet now.
IronHillRestorations |
Jul 26 2017, 06:18 AM
I. I. R. C. Group: Members Posts: 6,716 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Frank is right, if that is your car the clutch tube has pulled from the lower firewall and should be repaired. There are threads on this site that detail the repair.
Also there's remnants of the inner sleeve of the accel cable in that tube. Test fit your new accell cable and odds are that you'll have to cut a slot in the mount sleeve. |
Lo-Fi Version | Time is now: 5th May 2024 - 04:20 AM |
