> silicone hydraulic fluid, why not DOT5 silicone?
worn
post Jul 29 2017, 10:57 AM
We run silicone brake fluid in our LBCs (Little British Cars) and this is widely accepted among that crowd. This week I am putting new front wheel cylinders in the 47 Dodge P.U. truck cause we don't run it enough and they pitted.
So why not use the silicone fluid in a 914? Yes, there is a slight compression you can feel in the pedal, but in my TR6 you can hardly feel it. I now have enough toys so that routine maintenance is a pretty big chore. Keeping up with batteries and tires is bad enough. Yes, I know that you should bleed out the old fluid, but frankly I doubt that would have helped me with the truck. The problem was the lack of movement of the seals over the cylinder. My time flies!
So - what do you think?
Thanks,
Warren
- Lo-Fi Version Time is now: 30th June 2025 - 10:15 PM
