Porterfield brake pads, are good. |
phantom914 |
May 17 2005, 10:02 AM
non-914-owner non-club member Group: Benefactors Posts: 1,013 Joined: 24-February 04 From: Covina,CA(North ofWest Covina) Member No.: 1,708 |
Hawk HPS are good street pads, comparable to the Porterfield R4-S. And yes, I am saying this from direct experience. They don't make a Hawk pad for the 914 rear though. I got my pads at Livermore Performance, a place I thought I had discovered, but I guess others here have already heard of them. They seemed like good people. Andrew |
tat2dphreak |
May 17 2005, 10:17 AM
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) they were good people to me... I wasn't 100% sure which pads I actually needed since my car is a mid-72, and use the 73+ calipers... they knew, and made sure I got the right ones.... |
nebreitling |
May 17 2005, 10:49 AM
trek -- did you toss the prop valve and use a T?
MarkG |
May 17 2005, 01:56 PM
Member Group: Members Posts: 314 Joined: 24-May 04 From: Colorado Springs Member No.: 2,102 |
I added the Porterfield R4S pads to the 914 when I did the brake job last week.
Had them on the 308, had to do a panic stop on the mountain road to Cripple Creek to avoid hitting some moron stopped in the middle of the road to look at Deer or something......thought my eyeballs were going to pop out!! |
Trekkor |
May 17 2005, 04:22 PM
No... (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif) If I get the SS lines, then maybe I'll try the "tee". The feel with the prop valve in place is very good. We'll see. KT |
Mueller |
May 17 2005, 04:26 PM
I'm pretty sure that you can turn the 914 front pads into rear pads by opening up one of the holes for the pins....pads are identical except for one hole on each pad..... |
phantom914 |
May 17 2005, 04:31 PM
That's what I remember reading on the site before, but it's not true. The rear pads are physically smaller. I think the rear pads from some makers are 911(?) pads because the rear Porterfields I got had the same size holes rather than one small and one large hole so I had to enlarge one hole on each pad. Andrew |
Brad Roberts |
May 17 2005, 04:33 PM
Correct:
The front 914 pads are much bigger than the stock 914 rear pads. We have to drill out all the Porterfield *rear* pads. B |
ArtechnikA |
"just" get 914.6 rear calipers and you will be able to find pads ...
Trekkor |
May 17 2005, 04:34 PM
Yep, same story here. KT |
Lo-Fi Version | Time is now: 5th May 2024 - 06:59 AM |
