My Side Windows Leak |
solex |
Aug 4 2017, 01:11 PM
Senior Member Group: Members Posts: 789 Joined: 12-January 05 From: Long Island, NY Member No.: 3,439 Region Association: North East States |
I have tried adjusting the side windows every which way. There is absolutely no sag in the doors.
Turns out this morning we had a down pour when I need to bring my car in for an inspection. I replaced the side window rubber from (Mikey) but I'm thinking that the top rear gasket needs to be replaced. I just looked at another 914 and it seems to sit much lower. Also the point above the vent wing has a gap, does this mean the top window rubber needs to be replaced or does the front rubber on the window frame need replacement What do you think? Pictures have been attached for this morning. |
Montreal914 |
Aug 4 2017, 01:51 PM
Senior Member Group: Members Posts: 1,566 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
You might want to red this thread. Not saying this is the problem, but the more you know the better you will be able to asses the problem as there might be many things that need to be properly reset.
http://www.914world.com/bbs2/index.php?showtopic=249131 Also, there are 2 versions of tops for our cars, early and late. I would first determine if you have the correct one. Again, I don't think it's the problem but just giving you some leads on what to look for to make sure you have the right setup. Others will chime in... |
Lo-Fi Version | Time is now: 25th May 2024 - 06:18 PM |
