Front fender to Cowl Joint |
DennisO |
Aug 4 2017, 09:38 PM
Member Group: Members Posts: 61 Joined: 9-June 17 From: Clayton, NC Member No.: 21,162 Region Association: South East States |
Hi All,
I'm new to the 914 world. I've played with 356s and 911s for years, but never had a 914. I've always liked the 914, as friends had them when I was in high school. I recently bought a '75 1.7L project (Nepal Orange) that has been sitting in Central Calif since 2002. Overall, it does appear to be in decent shape for a car this old. It will require a complete restoration and my plans are turn to turn into a nice driver. I just started to disassemble the car and I am finding some rust but a vast majority of what I finding appears to be just surface rust. Hopefully as I complete the disassembly and engine removal I won't find any nasty surprises. The only accident damage I've found is the front corner of the driver's finder has been replaced. The rest of the car looks extremely straight. As I removed the front hood, I noticed that both front fenders have cracks in the seam where it meets the cowl. Attached are pictures of the area that I'm concerned about. Are these normal for a 914 or is this a sign of accident damage? Thanks in advance. |
cary |
Aug 4 2017, 09:43 PM
You've removed the entire front trunk seal and thats the only issue you see ?
ConeDodger |
Aug 4 2017, 09:44 PM
Apex killer! Group: Members Posts: 23,589 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
If it's a '75, it would be a 1.8 or 2.0. Not finding rust is rare indeed.
Get to know 914Rubber.Com. You'll need their help. Good luck with the project! |
ConeDodger |
Aug 4 2017, 09:45 PM
DennisO |
Aug 4 2017, 09:47 PM
I found that the front corner of the driver fenders has been replaced. I did find some minor rust spots that will need to be repaired. Otherwise, Nothing else yet.
I take it these are not normal for a 914? |
DennisO |
Aug 4 2017, 09:48 PM
yes, it's a 1.8L. I can't type.
dgraves |
Aug 4 2017, 10:08 PM
1974 914 2.0 Group: Members Posts: 180 Joined: 6-June 16 From: Montana Member No.: 20,076 Region Association: Rocky Mountains |
yes, it's a 1.8L. I can't type. I had light rust under that rubber seal as well. I don't think it's indicative of an accident. 914Rubber will be your new best friend. Save time, headaches, and effort...after the paint get the entire set of rubber seals. You'll be glad. |
ConeDodger |
Aug 4 2017, 10:21 PM
I found that the front corner of the driver fenders has been replaced. I did find some minor rust spots that will need to be repaired. Otherwise, Nothing else yet. I take it these are not normal for a 914? Common rust areas are: Battery tray "Hell hole" (under battery tray) If these two are allowed to run wild the whole suspension console and longitudinal on the passenger side can go with it. Also the engine seal channel on that side will rust. Trailing edge of the floor under the seats Trailing edge of the rear trunk floor. The cowl, particularly at the area by those two seams. Besides these particular areas I've mentioned, the 914 will feel free to rust anywhere it wants. On a quiet day, if you listen carefully, you can hear your 914 rusting. Now that I've thoroughly depressed you, (IMG:style_emoticons/default/welcome.png) |
Freezin 914 |
Aug 4 2017, 10:38 PM
Senior Member Group: Members Posts: 862 Joined: 27-July 14 From: Wisconsin Member No.: 17,687 Region Association: Upper MidWest |
I found that the front corner of the driver fenders has been replaced. I did find some minor rust spots that will need to be repaired. Otherwise, Nothing else yet. I take it these are not normal for a 914? Common rust areas are: Battery tray "Hell hole" (under battery tray) If these two are allowed to run wild the whole suspension console and longitudinal on the passenger side can go with it. Also the engine seal channel on that side will rust. Trailing edge of the floor under the seats Trailing edge of the rear trunk floor. The cowl, particularly at the area by those two seams. Besides these particular areas I've mentioned, the 914 will feel free to rust anywhere it wants. On a quiet day, if you listen carefully, you can hear your 914 rusting. Now that I've thoroughly depressed you, (IMG:style_emoticons/default/welcome.png) (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/lol-2.gif) sadly true, but still funny! (IMG:style_emoticons/default/welcome.png) |
Matty900 |
Aug 5 2017, 02:40 AM
Senior Member Group: Members Posts: 1,269 Joined: 21-February 15 From: Oregon Member No.: 18,454 Region Association: Pacific Northwest |
(IMG:style_emoticons/default/welcome.png) On the fender to cowl gap there is actually a drain gap in there tha needs to be cleaned out to allow it to work.
Congratulations on acquiring the car and all of you new friends you will find here. (IMG:style_emoticons/default/beerchug.gif) |
cary |
Aug 5 2017, 06:33 AM
All kidding aside. Get an inspection mirror and take a look at the crack from the bottom and backside. Generally all the corner areas under the seal have some sort of rust issues.
I'm working on a car right now where the hood wasn't latched and it folded back and damaged the same area. Side note : fender side of that crack is one of the strongest in the car. I'd get a small wire brush and try and clean the entire channel to get down to the paint. Paying close attention to the corners around the headlights and the rounded section at the front latch. |
Shadowfax |
Aug 5 2017, 07:40 AM
Show us the meaning of haste Group: Members Posts: 509 Joined: 19-January 15 Member No.: 18,340 Region Association: South East States |
Any more pics of the car you could share? |
DennisO |
Aug 5 2017, 08:23 AM
Thanks Guys. I will do more investigation and report what I find.
I'll post some more pics. My phone take HD pics and I need to resize them in order to post. |
Cairo94507 |
Aug 5 2017, 09:45 AM
Michael Group: Members Posts: 9,759 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Yes, I would expect to find more rust, but you never know. You may get lucky and just have minor rust. The best thing is you are identifying and tackling the rust issues before doing anything else. I believe that is the way to approach these cars. Get the foundation solid before you build from there. Good luck and keep the pictures coming. Cheers. (IMG:style_emoticons/default/beerchug.gif) |
whitetwinturbo |
Aug 8 2017, 10:17 PM
Honey, does this wing make my ass look fat? Group: Members Posts: 1,391 Joined: 22-October 11 From: Newport Beach/Kalefornya/USA Member No.: 13,704 Region Association: Southern California |
(IMG:style_emoticons/default/beer3.gif) ...........welcome to OUR world
Lo-Fi Version | Time is now: 18th May 2024 - 12:11 AM |
