Front end shimmy, steering |
WHO |
May 17 2005, 04:05 PM
Newbie Group: Members Posts: 12 Joined: 13-May 04 From: Denver, Colorado Member No.: 2,065 |
I've tried wheel bearings, tie rods, wheel balance and alignment but my shimmy over 60mph is still there! what's next? Ball joints? Bushings??
SGB |
May 17 2005, 04:06 PM
have you checked the tires for roundness?
Joe Bob |
May 17 2005, 04:09 PM
Or balance...
TravisNeff |
May 17 2005, 04:21 PM
Bent wheels. BTDT, go see how many balance weights are on all your wheels. You'd want the ones with the least amount of weights on the fronts -but that may mess you up if you have directional tires.
I had a wheel with 21 1/4 ounce balance weights on them. just a "little" shimmy ha! |
Mark Henry |
May 17 2005, 04:36 PM
Yep...I had "good" but old tires that shifted a belt. |
Rand |
May 17 2005, 05:02 PM
Any good tire shop should be able to put your wheels on a machine and tell you real quick if there's a problem with a wheel or tire. Easy and quick thing to do next before digging deeper.
Brad Roberts |
May 17 2005, 05:26 PM
I'm betting it is the tires. I just ran across this recently. The tire balance machine doesnt know when there is a seperated belt in a tire. It wont show while balancing (no weight on the tire).
B |
redshift |
May 17 2005, 05:37 PM
I have a 'going bad' rear driver's side tire... waaaab waaab waaab..
I say tire. M |
Rand |
May 17 2005, 05:42 PM
Ok. But, can't you visually examine the perimeter while it's spinning on the machine and see when things are out of round or untrue even if the machine says it's in balance? |
scotty b |
May 17 2005, 05:44 PM
Look at the tires straight on withh full pressure and if it/they are cupping in the ceneer get new ones. Tires will actually seperate internally, and start to pull apart and wobbling is the first sign. Ask me how I know (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Had a tire pulling apart on a CJ-7 with 33-12.50's. Fun ride! (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif)
Does this pass the Capn's info test ??? I don't want to be a sinner |
Brad Roberts |
May 17 2005, 05:47 PM
Not easily. 99% of the tire machines nowadays are OSHA compliant with a big fat cover over the spinning combination. A lot of the tire issues wont be "visible" unless their is weight on the tire. B |
Rusty |
May 17 2005, 05:49 PM
What year struts and what year wheels do you have?
Early Pedrinis won't mount flush to a later car, and will cause a shimmy that balancing won't fix. If the wheels are balanced off the car, you won't see it. I speak from experience. |
TravisNeff |
May 17 2005, 06:00 PM
To check out my wheels, I had them dismounted and then put the wheels alone on the balancing machine.
Lo-Fi Version | Time is now: 5th May 2024 - 04:15 AM |
