Grounding through throttle cable, Return spring burned the crap outta me! - SOLVED |
clapeza |
Aug 8 2017, 07:14 PM
Member Group: Members Posts: 229 Joined: 7-February 11 From: South GA Member No.: 12,677 Region Association: South East States |
Got the FI back in my car (1970 1.7L) and working recently. The PO had cut the throttle cable for the carb conversion, so I installed a new TerryCable.
I noticed that the throttle cable got hot. I figured that the ground strap was corroded or broken (I can see it, but can't get to it now.) I installed a new ground from the rearmost engine case bolt to the battery ground stud on the passenger side of the engine compartment. I used a generic 4 ga battery ground cable from my FLAPS. One end is on top of the battery ground cable. The other is on the bolt that holds the oil bath air cleaner "shelf". This end of the cable is sandwiched between 2 washers on top of the shelf arm that the bolt goes through, with the nut holding it all down tight. I cranked the car and it ran easily, and the throttle cable was no longer hot, or even warm. Success? Not so fast... I then replaced the bushings in the accelerator pedal bracket, so it's nice and smooth now. Didn't get a chance to crank it because I ran out of time that day. I cranked it today, and blipped the throttle by hand on the throttle body. I thought I saw a tiny spark at the throttle return spring where it attaches to the rear wall. I touched the spring lightly with my finger and burned the crap out of it! The engine had been running only about 10 seconds at this point. What gives? Theory: The new accelerator pedal bushings improved the electrical connection to the body. The new grounding cable isn't making good enough contact to the engine case, so the engine is still preferring to ground through the throttle cable. Assumption: A 4ga cable connected from the engine case straight to the body where the battery connects is an equal (if not superior) ground compared to the transmission ground strap. I still plan on inspecting and possibly replacing the transmission ground strap, but I'm curious as to why I burned my finger... Ideas? Advice? |
Spoke |
Aug 9 2017, 05:09 AM
Jerry Group: Members Posts: 6,978 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I cranked it today, and blipped the throttle by hand on the throttle body. I thought I saw a tiny spark at the throttle return spring where it attaches to the rear wall. I touched the spring lightly with my finger and burned the crap out of it! The engine had been running only about 10 seconds at this point. Did the arcing happen as the engine was cranking or running? If while running, that means the alternator is not grounded and battery charging current is flowing through the spring and cable. The grounding of the alternator goes through the 4 small studs and nuts that hold the fan shroud to the engine case since the alternator is bolted to the fan shroud. You may need to add a ground strap from the alternator case to the engine case. You should fix or replace the transmission ground cable and remove the cable from the engine case to battery. The basic 914 engine grounding scheme is perfectly fine if all the components are in good shape and the connections are clean, shiny, and secure. |
clapeza |
Aug 9 2017, 06:26 AM
I cranked it today, and blipped the throttle by hand on the throttle body. I thought I saw a tiny spark at the throttle return spring where it attaches to the rear wall. I touched the spring lightly with my finger and burned the crap out of it! The engine had been running only about 10 seconds at this point. Did the arcing happen as the engine was cranking or running? If while running, that means the alternator is not grounded and battery charging current is flowing through the spring and cable. It was while running. Yikes! (IMG:style_emoticons/default/yikes.gif) Looks like my to-do list just grew. (x) Remove, clean, replace transmission ground strap. (x+1) Inspect alternator mounting bolts, and possibly install new ground from alternator case to engine case. ... (x+50) DRIVE IT! I applaud the collective knowledge and helpfulness of this board. Thanks, guys!! |
Lo-Fi Version | Time is now: 3rd May 2024 - 06:58 AM |
