GB -6 mufflers in stainless |
mb911 |
Aug 8 2017, 07:37 PM
914 Guru Group: Members Posts: 6,811 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
So after all of the testing we have good feed back. The mufflers are quiet as stock and flow a bit better over stock as larger id tubing internally. We still have to tweak the tail pipe locations and may ask for a little assistance with that. I am going to offer 10 of them at 650 for intro pricing and then 900 after that. They will be made 100% of 304 stainless weighs 18lbs, 2.5 dia tail pipe, installation kit will be included, shipping will be extra and to be determined.
Cairo94507(Michael) is 1st on the list so 1 more spot.(deposit ) 914forme (Stephen) Steve ( aka steve;)( deposit) Live free +drive (jon) (deposit) Rktmn247 (kent) (deposit) MEpstein(Mark) doesn't count for group buy Restore2seater (Pat)(deposit) Dion Marv E Mark Howard. Jmuriz (Nathan) Deposits will be 300. I will post pictures as we progress just as I did with the heat exchangers project with delivery in November.. Please let me know if you have any questions. |
live free & drive |
Nov 3 2017, 11:56 AM
Member Group: Members Posts: 154 Joined: 29-June 16 From: New Hampshire Member No.: 20,159 Region Association: None |
Would it be possible to have added 1 1/2" to 2" to the inlet pipes for people (like me, among others) who are running a 915 trans?
Maybe for an upcharge you could provide the modification vs. having to insert/create spacers? I'm working on a 3.2 with a 915 and your HE's - I have a Vellios tail-cone, but currently have installed a stock tail-cone (with reduced features) and the PMS steel adapter frame. From my measurements the Vellios tail-cone is about 3/4" shorter than the stock tail-cone casting (measured including nothing beyond the casting surface) so I'm assuming it's going to interfere with the muffler. |
mb911 |
Nov 4 2017, 07:09 AM
Would it be possible to have added 1 1/2" to 2" to the inlet pipes for people (like me, among others) who are running a 915 trans? Maybe for an upcharge you could provide the modification vs. having to insert/create spacers? I'm working on a 3.2 with a 915 and your HE's - I have a Vellios tail-cone, but currently have installed a stock tail-cone (with reduced features) and the PMS steel adapter frame. From my measurements the Vellios tail-cone is about 3/4" shorter than the stock tail-cone casting (measured including nothing beyond the casting surface) so I'm assuming it's going to interfere with the muffler. Its possible.. The problem is that almost every order I had on the group buy wanted something special or custom and it makes very hard to break even on the project when I finish everything up.. That said its possible on this to do the upcharge as you describe. |
Steve |
Nov 4 2017, 10:32 AM
914 Guru Group: Members Posts: 5,569 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Would it be possible to have added 1 1/2" to 2" to the inlet pipes for people (like me, among others) who are running a 915 trans? Maybe for an upcharge you could provide the modification vs. having to insert/create spacers? I'm working on a 3.2 with a 915 and your HE's - I have a Vellios tail-cone, but currently have installed a stock tail-cone (with reduced features) and the PMS steel adapter frame. From my measurements the Vellios tail-cone is about 3/4" shorter than the stock tail-cone casting (measured including nothing beyond the casting surface) so I'm assuming it's going to interfere with the muffler. Its possible.. The problem is that almost every order I had on the group buy wanted something special or custom and it makes very hard to break even on the project when I finish everything up.. That said its possible on this to do the upcharge as you describe. 2” would be awesome. Maybe standardize on a 915 version and make a bunch of them. |
Lo-Fi Version | Time is now: 26th April 2024 - 05:20 AM |
