GB -6 mufflers in stainless |
mb911 |
Aug 8 2017, 07:37 PM
914 Guru Group: Members Posts: 6,812 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
So after all of the testing we have good feed back. The mufflers are quiet as stock and flow a bit better over stock as larger id tubing internally. We still have to tweak the tail pipe locations and may ask for a little assistance with that. I am going to offer 10 of them at 650 for intro pricing and then 900 after that. They will be made 100% of 304 stainless weighs 18lbs, 2.5 dia tail pipe, installation kit will be included, shipping will be extra and to be determined.
Cairo94507(Michael) is 1st on the list so 1 more spot.(deposit ) 914forme (Stephen) Steve ( aka steve;)( deposit) Live free +drive (jon) (deposit) Rktmn247 (kent) (deposit) MEpstein(Mark) doesn't count for group buy Restore2seater (Pat)(deposit) Dion Marv E Mark Howard. Jmuriz (Nathan) Deposits will be 300. I will post pictures as we progress just as I did with the heat exchangers project with delivery in November.. Please let me know if you have any questions. |
mb911 |
Nov 22 2017, 07:01 AM
Looks like tail pipe diameter off..
Steve |
Nov 22 2017, 08:37 AM
914 Guru Group: Members Posts: 5,570 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Looks like tail pipe diameter off.. It looks like it needs to move over exactly 2” to the right. It’s still on the car if you want me to take more measurements or pictures. Otherwise I can take it off and send it back. I didn’t start the car up. Something else interesting... I did not use my 1.5" spacer. There was enough clearance without it. However... The muffler is exactly 1.5" from the rear heat shield. I am curious how this will effect WEVO installations, since they typically require a 2" extension since they are a tail shifter. |
mb911 |
Nov 22 2017, 10:50 AM
Looks like tail pipe diameter off.. It looks like it needs to move over exactly 2” to the right. It’s still on the car if you want me to take more measurements or pictures. Otherwise I can take it off and send it back. I didn’t start the car up. Something else interesting... I did not use my 1.5" spacer. There was enough clearance without it. However... The muffler is exactly 1.5" from the rear heat shield. I am curious how this will effect WEVO installations, since they typically require a 2" extension since they are a tail shifter. I may have you send it to Mark.. otherwise it will work for a later 911 as well and I think I have one customer waiting on that.. Steve please confirm everything else is correct for height and angle and just moving to the right closer to the muffler by 2" will do whats needed.. Once we know that I will send you another one with corrected tail pipe.. let me know or text me later today |
Lo-Fi Version | Time is now: 26th April 2024 - 03:42 PM |
