GB -6 mufflers in stainless |
davehg |
Nov 4 2017, 05:41 PM
Member Group: Members Posts: 183 Joined: 19-September 17 From: PNW Member No.: 21,443 Region Association: Pacific Northwest |
mb911 |
Nov 4 2017, 06:17 PM
914 Guru Group: Members Posts: 6,839 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Updated did I forget anyone? I need to get invoices out for the remainder of you that put deposits down. I should be on your list - paypal payment sent in full You are but not part of the group buy.. The buyers in front of you are 1st to have product delivered.. |
mb911 |
Nov 9 2017, 06:43 PM
Finishing 1st one this weekend and need to ship next week to the 1st person that can test fit right away on there 901 based trans -6 and confirm everything is good .. We will build the bulk of the muffler body's next week and wait for confirmation of fitment before welding on tail pipes..
mb911 |
Nov 12 2017, 12:32 PM
mb911 |
Nov 13 2017, 07:35 PM
1st on goes out to stephen tomorrow.
mb911 |
Nov 14 2017, 10:19 AM
Also still have to work out a 911 style muffler hanging installation setup. These mufflers should not be supported just from the inlets..
Nov 14 2017, 10:52 AM
914-6 GT in waiting Group: Members Posts: 19,260 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Mine is sort of rigged up the 2.0 hanger. I would like something that looks good and works correctly.
GeorgeRud |
Nov 15 2017, 12:09 PM
Though not elegant, an extra flange between the heat exchanger and the muffler with extra gaskets would provvbably be the easiest way to obtain any needed clearance. Much easier than modifying the mufflers or heat exchangers for those few folks that need this. I wonder how many folks are actually running 915 transmissions in their cars?
Steve |
Nov 15 2017, 01:23 PM
914 Guru Group: Members Posts: 5,580 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
For me and my Martin Bott 916 kit a 2” spacer would be perfect. I agree.. extending the pipes on the muffler will hurt the resale value for cars that don’t need the clearance. Ben made me 1.5” spacers that work, but I had to use studs versus bolts, due to limited space between the flanges on the spacer.
mb911 |
Nov 15 2017, 03:06 PM
Steve once you get the muffler we will have to look at options for a 911 style support..
Steve |
Nov 15 2017, 05:19 PM
Some of the other local six conversions are using a log type muffler that use the straps around the muffler versus the hanger. I will find out how they made it.
mb911 |
Nov 21 2017, 06:57 AM
Steve should have received his last night.. Once we get updates we will be ready to start shipping the rest..
Steve |
Nov 21 2017, 08:30 AM
I received it last night at 8pm. Amazing workmanship! I will try to install it in the next couple of days depending on work schedule. I will post a bunch of pictures. I also have an old MSDS single exit muffler that I will compare the exit pipe with, since my Triad exhaust tips have been modified.
mb911 |
Nov 21 2017, 05:34 PM
I received it last night at 8pm. Amazing workmanship! I will try to install it in the next couple of days depending on work schedule. I will post a bunch of pictures. I also have an old MSDS single exit muffler that I will compare the exit pipe with, since my Triad exhaust tips have been modified. Great news.. We have all the internals done for the rest of the mufflers just need a final approval for tail pipes.. |
Steve |
Nov 21 2017, 10:29 PM
I received it last night at 8pm. Amazing workmanship! I will try to install it in the next couple of days depending on work schedule. I will post a bunch of pictures. I also have an old MSDS single exit muffler that I will compare the exit pipe with, since my Triad exhaust tips have been modified. Great news.. We have all the internals done for the rest of the mufflers just need a final approval for tail pipes.. Bummer... but it's off. This is with no spacer. |
Steve |
Nov 21 2017, 10:31 PM
mb911 |
Nov 22 2017, 07:00 AM
That is a bummer.. Wow .. Its way off.. Ugh..we will get that corrected..
mb911 |
Nov 22 2017, 07:01 AM
Looks like tail pipe diameter off..
Nov 22 2017, 07:38 AM
It would work for me, I don’t run a rear valance.
Steve |
Nov 22 2017, 08:37 AM
Looks like tail pipe diameter off.. It looks like it needs to move over exactly 2” to the right. It’s still on the car if you want me to take more measurements or pictures. Otherwise I can take it off and send it back. I didn’t start the car up. Something else interesting... I did not use my 1.5" spacer. There was enough clearance without it. However... The muffler is exactly 1.5" from the rear heat shield. I am curious how this will effect WEVO installations, since they typically require a 2" extension since they are a tail shifter. |
Lo-Fi Version | Time is now: 10th May 2024 - 08:24 PM |
