Need 3.2 conversion electrical help |
mepstein |
Aug 13 2017, 12:20 PM
914-6 GT in waiting Group: Members Posts: 19,272 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I can't get my fuel pump to run unless I jumper the plug for the DME relay. The car starts and runs with the connection jumped but the fuel pump then runs all the time. Just want to know where to look and what to do.
I'm very electrically challenged so you might need to really dumb it down for me. Thanks |
jim912928 |
Aug 16 2017, 05:30 PM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
The AFM point is a good one. Before I put my 3.2l I had a 1.8l ljet. It sat long enough that the flapper "hinges?" got kind of corroded and stuck. The cranking of the engine and the compression wasn't enough to open it. After doing the test above and then hearing the fuel pump turn on...some lub and I was good to go.
Lo-Fi Version | Time is now: 18th May 2024 - 03:40 AM |
