74 911 sway bar mounting location |
mb911 |
Aug 14 2017, 01:40 PM
914 Guru Group: Members Posts: 6,831 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
So I know I will have a bunch of folks saying to go with the through body sway bar up front but I prefer not to. I have a very nice powdercoated 74 911 front sway bar and would like to weld the brackets to my 914 suspension arms. Does anyone have exact dimensions so I can get them set perfect before I powder coat?
GeorgeRud |
Aug 14 2017, 07:22 PM
I could perhaps get you some measurements off my Targa on Friday if I can get it up on the rack once it's free. Let me know if you couldn't get one sooner. Did you also post on the 911 Pelican Parts forum? Someone may have photos there.
mb911 |
Aug 14 2017, 07:32 PM
I could perhaps get you some measurements off my Targa on Friday if I can get it up on the rack once it's free. Let me know if you couldn't get one sooner. Did you also post on the 911 Pelican Parts forum? Someone may have photos there. Unfortunately George yours would not be the same at least I don't believe it will be? Let me know if I am mistaken |
GeorgeRud |
Aug 14 2017, 07:37 PM
The 914s are through the body, but I think the 911 is the later underbody style (it's an '84 model 911). Check you email for a photo that may help you position the mounts.
gms |
Aug 16 2017, 09:21 AM
Advanced Member Group: Members Posts: 2,694 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
Ben the dimension for the front suspension are the same (914 & 911) up until 1989.
are you using and aluminum crossmember? |
mb911 |
Aug 16 2017, 10:44 AM
Ben the dimension for the front suspension are the same (914 & 911) up until 1989. are you using and aluminum crossmember? Yes I have an aluminum crossmember already restored and waiting. I am planning to use the 914 a arms as I already have them and don't have 911 ones and then new t bars for 914 spline.. Do you think that is a sound plan. Please note this will be 100% street driven car so thats why I felt should work well. |
914Sixer |
Aug 16 2017, 07:04 PM
914 Guru Group: Members Posts: 8,876 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Your plan is sound and will work once you get the bar tabs swapped out. Make sure you have the front bar straps.
porschetub |
Aug 16 2017, 08:26 PM
Change for the correct support mount for the alloy beam and weld on mounting tabs on to the A arms should be fine.
I note Porsche sells the support piece/swaybar mount new for $123 each,hopefully you can find some used ones cheaper ,good luck |
funk |
Aug 16 2017, 09:23 PM
Member Group: Members Posts: 100 Joined: 23-June 14 From: sandpoint idaho Member No.: 17,531 Region Association: Pacific Northwest |
please see aase sales they have the crossmember supports for 50 bucks a pair!!
mb911 |
Aug 17 2017, 03:13 AM
Eric_Shea |
Aug 17 2017, 08:53 AM
PMB Performance Group: Admin Posts: 19,274 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
larryM |
Aug 20 2017, 09:41 PM
emoze Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California |
replied to this duplicate post you put on Pelican - with pics
http://forums.pelicanparts.com/porsche-911...tml#post9707454 So I know I will have a bunch of folks saying to go with the through body sway bar up front but I prefer not to. I have a very nice powdercoated 74 911 front sway bar and would like to weld the brackets to my 914 suspension arms. Does anyone have exact dimensions so I can get them set perfect before I powder coat? |
mb911 |
Aug 21 2017, 08:28 AM
replied to this duplicate post you put on Pelican - with pics http://forums.pelicanparts.com/porsche-911...tml#post9707454 So I know I will have a bunch of folks saying to go with the through body sway bar up front but I prefer not to. I have a very nice powdercoated 74 911 front sway bar and would like to weld the brackets to my 914 suspension arms. Does anyone have exact dimensions so I can get them set perfect before I powder coat? Thanks that is helpful.. |
Tdskip |
Jul 22 2019, 12:10 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Yes, yes, i know this post is from 2017.
@mb911 - did you get this installed like this? Happy with it? |
Jul 22 2019, 12:45 PM
914-6 GT in waiting Group: Members Posts: 19,256 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Yes, yes, i know this post is from 2017. @mb911 - did you get this installed like this? Happy with it? I sent Ben some 911 A arms and new torsion bars so I'm pretty sure he is using them. He wants the under the car bar. (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/screwy.gif) (IMG:style_emoticons/default/lol-2.gif) |
mb911 |
Jul 22 2019, 06:10 PM
Yup installed in the car.. I did this on my last car as well.. Works well.
Lo-Fi Version | Time is now: 7th May 2024 - 08:25 PM |
