Rubber mounts for Fuel Pump.., how necessary are they? |
DougC |
May 18 2005, 09:19 AM
Senior Member Group: Members Posts: 949 Joined: 6-July 04 From: Dallas, TX Member No.: 2,307 |
A while back I bought a generic fuel pump from Autozone because I was planning a V8 conversion, then I changed my mind and will be going flat six. Anyway, I have my stock Porsche fuel pump for the CIS injected motor but no mounts. The generic "autozone" pump just came with a round bracket and the Porsche pump fits it...so, can I just use that or is it so much better and necessary to get rubber mounts for it? Where to get them?
Doug C |
freezing14 |
May 18 2005, 09:26 AM
freezing14 Group: Members Posts: 435 Joined: 21-June 04 From: brockville , Ontario, Canada Member No.: 2,233 |
When I did the relocation of my fuel pump under the tank i did not have the rubber mount,, and so i installed it like that, I did not have the engine running before i installed it in there,, but now i am gladit does not have the mount,, when I start the car, i can always hear it running ( or not if there is a problem) and once the car is running i do not hear it anymore, but so far no problem
echocanyons |
May 18 2005, 09:32 AM
Advanced Member Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
It is mounted with rubber mounts to dampen the vibration from the pump.
Not sure they are entirely necessary but I have always tried to utilize them even on my carbed 914. I just picked up a pair from GPR for 6bucks each. |
Lo-Fi Version | Time is now: 5th May 2024 - 09:29 AM |
