Early Handbrake Lever, Is this pin original? |
gcrotvik |
Aug 15 2017, 07:41 AM
Member Group: Members Posts: 360 Joined: 16-December 09 From: Portland Oregon Member No.: 11,134 Region Association: Pacific Northwest |
I purchased an early handbrake assembly. I was surprised to see the clevis pin used to hold the cable to the handbrake assembly. Is this correct or did someone get inventive?
Thanks, Greg Attached image(s) |
914work |
Aug 17 2017, 08:47 AM
Member Group: Members Posts: 291 Joined: 9-November 11 Member No.: 13,762 Region Association: None |
Um...beg to differ.
Ive seen more than my share of these cars and Ive only seen that fasteners used to hold the Accel cable clevis to the pedal cluster. What I think should be there is a Pin with a slot on the bottom for a retaining clip. The pin is similar to those used at the R. e-brake actuating arm, but longer to fit thru the multi part end of the short cable. That I can recall its the only one like it on the car. Though I must admit Ive never looked it up in PET |
gcrotvik |
Aug 20 2017, 11:26 AM
Um...beg to differ. Ive seen more than my share of these cars and Ive only seen that fasteners used to hold the Accel cable clevis to the pedal cluster. What I think should be there is a Pin with a slot on the bottom for a retaining clip. The pin is similar to those used at the R. e-brake actuating arm, but longer to fit thru the multi part end of the short cable. That I can recall its the only one like it on the car. Though I must admit Ive never looked it up in PET I looked in the PET and it shows only the pin with the clip. No different part or part number for early cars. |
Lo-Fi Version | Time is now: 19th May 2024 - 06:06 AM |
