OT,unloved car..., bites my wallet |
porschetub |
Aug 16 2017, 11:12 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Well long story short had a buyer lined up for my 2.7 powered early 944 and my later 89 parts car,I park up the 914 and in my head think the running car will go again but after cranking find the reference and position sensors are faulty, replaced them and got the right result.
Then I lost spark sounds like another 914 story as the ignition switch in the early 944 is a very similar part,all is good after replacement and have spark and injector pulse,progress I think but engine is cranking slow,sometimes firing but @ what appears to be out of order (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) . End of story have really bad cold compression in 2 cylinders and a nasty ticking Noise on turnover with plugs out and quess what bent valves,not impressed. Being a 2.7 it has a one year only head on a 3.0 block so the valves are NASA prices because the inlets are huge (48mm). Wasn't pleased so pulled the cover of the 914 and started it ,made me feel good for a while,so next question an otherwise nice 944 is worth little now....I suspect little ? I may drink tonight (IMG:style_emoticons/default/drunk.gif) . |
Krieger |
Aug 16 2017, 11:38 PM
Advanced Member Group: Members Posts: 4,705 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Dang! Now two parts cars. Can you make good $ parting it out? Maybe time for a V8 conversion...
Lo-Fi Version | Time is now: 10th May 2024 - 06:16 AM |
